Strange Brake Problems
Old Nov 2, 2021 | 10:46 AM
TristeTurismo's Avatar
I have brake problems. The issue is than neither I nor anyone else I've gotten to look at the car can figure out what it is. I'm fairly certain that it's entirely in the front end. The calipers, brake hoses, rotors, and pads were all replaced and bled over a year ago. Front calipers have seized up a few times since, and those were replaced.
Front brake pads have about 9mm left. It smells like burning brake pads... sometimes. The wheels are abnormally black with brake dust... but the wheels move freely when tested. The front end makes loud metallic clicking noises like something's overheating when stopped... but the wheels aren't unusually hot. Occasional slight burning coolant smell... probably related to said overheating. Brake pedal sinks... sometimes. Car jerks like it's braking unevenly... sometimes. Fuel mileage reading drops to single digits... sometimes.
Likely it's an uncommon cause, considering how it's completely baffled everyone. ABS? Master cylinder? Suspension component? Brakes seem to be dragging for some reason or another.
Thanks in advance.
Old Nov 2, 2021 | 06:29 PM
After screwing around with the car for a few hours, I think I've uncovered at least part of the problem. I think the master is on it's way out; the brake pedal sinks to the floor and stopping distance is longer than normal. The poor mileage might be caused by a clogged catalytic converter, but I'm not sure if it could be overheating the braking system. The heat coming from the underbody is pretty significant, and it's definitely coming from the exhaust system. The ABS might also be somehow involved in all of this; the car threw ABS fault codes a couple times after hard braking.
Found this helpful page: https://acurazine.com/how-tos/a/acur...ylinder-426385
Would a couple liters of brake fluid be enough to do it, or would I need more just in case?
Old Nov 3, 2021 | 02:21 PM
619rcr's Avatar
too many problems / symptoms to get any relevant help here. yes you can replace a master cylinder, but no guarantee it will cure everything you mentioned. It sounds unsafe to operate as is.
Old Nov 4, 2021 | 11:56 AM
Robbym's Avatar
Do you have the Brembo brakes? My brembos just starting doing this strange thing when I press on the brakes at a stop. They like click the more I push in the pedal at a stop. I can feel it in the brake pedal and hear it outside. Each side clicks a few times as I press the pedal down furthers brakes still work fine though.
Old Nov 4, 2021 | 08:16 PM
Pair of TLs's Avatar
Thanks in advance.
Well, paint me green and call me baffled, too.
Wait, who did the brake job(s)?
C2CuSn07 TL
Jun 19, 2016 10:05 AM
maclion
1G TSX Problems & Fixes
May 11, 2009 07:58 PM
mav238
1G RDX (2007-2012)
24
May 18, 2007 12:01 PM
AcuraBuddy
Apr 6, 2006 01:12 PM
slider2828
Mar 29, 2004 01:11 PM
