brake proble when backing
Old May 11, 2009 | 01:06 PM
maclion's Avatar
When I backing at low speed (especially when down slope), the car can still moving a little bit even I already brake to the deepest position. What is problem? I bought this used car from dealer, the dealer has detail the wheel wall and suspension, so I doubt if it is some detailing spray caused the pad/rotor grease? Does Brake cleaner help in this situation?
And I also worry if air in the brake system. If so how can I tell?
Old May 11, 2009 | 01:43 PM
PACman's Avatar
Sounds like a brake fluid problem. Bleed the brake fluids and replace with fresh Honda DOT 3. Also check condition of rotors and pads.
Old May 11, 2009 | 04:00 PM
maclion's Avatar
Thanks. I will do it this weekend. Also I feel hard brake pedal at the end of travel. Is that normal?
Old May 11, 2009 | 07:20 PM
PACman's Avatar
Are you also hearing/feeling metal on metal when you "feel hard brake pedal"? This would indicate your brake pads are toast, and need to be replaced.
Old May 11, 2009 | 07:58 PM
maclion's Avatar
metal on metal, en...I dont think so. Maybe I should let brake shop to check it first. Thanks
rockyboy
Aug 4, 2024 10:35 AM
nanos
Nov 12, 2015 08:41 PM
HOWELLiNC
Sep 10, 2015 01:39 PM
nuldabz
Sep 3, 2015 05:49 PM
