steering wheel Vibration???
Old Feb 20, 2009 | 12:09 PM
salu8819's Avatar
"Let's Do This"
Exclamation steering wheel Vibration???
For the past couple of months while driving on the parkways doing like 80mph, i feel the steering wheel vibrating slightly like it cant handle the speed....... i have a 05 TL 6spd with 53000 miles. Its making me dislike the car. and also i have bad axles, just throwing that in just in case
Old Feb 20, 2009 | 12:44 PM
RACINGHART03's Avatar
Originally Posted by salu8819
..... and also i have bad axles, just throwing that in just in case
Fix the known problem before trying to figure out another.
Old Feb 20, 2009 | 09:33 PM
DrMooCow's Avatar
Wocoomrd
Most likely it's your axles. Some places will be willing to straighten out your axles without having to put a brand new one in. A new axle will probably be expensive.
I recommend getting the axles fixed and then getting your wheels rebalanced.
Old Feb 24, 2009 | 01:19 AM
samdrvsatl's Avatar
my steering wheel vibrates when im going down from 100 till like 80 i think its because i need A wheel allingment but idk?
Old Feb 24, 2009 | 01:45 PM
lilripper's Avatar
no no no no your all wrong
problem-your brake rotors warped
how to fix-there 2 way to fix you problem either get you brake rotors machined or replaced and you might as well change out you pad as well
Old Feb 24, 2009 | 01:54 PM
samdrvsatl's Avatar
Should I take it to the dealer I only have like 23000 miles on it but its an 06 ? And my dad wouldn't be so happy with the idea of Me needing new brakes
Old Feb 24, 2009 | 04:11 PM
Majofo's Avatar
Originally Posted by racinghart03
fix the known problem before trying to figure out another.
+1
Old Feb 24, 2009 | 04:12 PM
Majofo's Avatar
-1 .. vibration while driving 80 mph not braking from 80 mph.
Old Feb 24, 2009 | 04:13 PM
Majofo's Avatar
get new driveshafts if they're bad.. then get front alignment.
Old Mar 3, 2009 | 03:38 PM
wsrydah33's Avatar
i'm actually experiencing the same problems now, i have a 05at with only 39.5k miles... but when i let go of the steering wheel, the car turns left...but the crazy thing is that the steering wheel vibrates making my interior rattle. i'm hoping it's just the shocks...how did your axles get bad?
Old Mar 3, 2009 | 03:44 PM
PhilB81's Avatar
i think he was referring to the other person that said the vibration occurs when slowing down from 100 to 80. which does sound like rotors (assuming slowing down includes braking not just coasting and letting wind drag do the work).
Old Mar 3, 2009 | 03:59 PM
Majofo's Avatar
I don't think so.. b/c he said NO NO NO NO YOU"RE ALL WRONG right after the 100 - 80 post.
Old Mar 3, 2009 | 05:37 PM
BHump's Avatar
And 100 to 80 would infer slowing down, ie, braking.
Old Mar 10, 2009 | 07:12 PM
rkwala's Avatar
I have a 04 TL with 68k on it. Same problem. Just put new aspec rims on it and still have the same problem. Steering vibration at 75+. Dealer said they will take a look at it and install these dampers that attach to the subframe of the car. I pick it up tomorrow night. Will let you know what happens.
Old Mar 11, 2009 | 08:23 PM
rkwala's Avatar
Ok, Steering Vibration dramatically reduced by dealer installing dampers to the subframe. This may be the answer to many of your similar problems.
Old Mar 11, 2009 | 09:13 PM
PeterUbers's Avatar
had the same problem -- my axles were replaced, wheels re-balanced -- problems solved... rock stable at 80,90,100mph, braking is smooth at all speeds.
95k on the odo.
Old Mar 11, 2009 | 10:19 PM
Fresh23's Avatar
How much did the axles run you?
Old Mar 12, 2009 | 01:04 PM
PeterUbers's Avatar
ugh... $550 a piece .. i got ripped from the dealer .. shoulda gone with a non-acura mechanic
Old Mar 12, 2009 | 01:06 PM
PeterUbers's Avatar
to the OP, why not try rebalancing the tires first? It's like $50-80 to do all four wheels ..
Old Mar 12, 2009 | 11:00 PM
spree-dakid's Avatar
hey im having the same problem too, 04 tl 66k and having the same problems so i got my wheel balance and rotate today...so far i feel a difference but haven't have the chance to take it up to 80mph yet. Let me know what happens when you pick your car up.
Old Mar 12, 2009 | 11:24 PM
Majofo's Avatar
Holy *ish.. bought mine from Advance Auto Parts Online.. GSP shafts for $69.99 each [$140 - free s/h] then another ~$150 to put them in by my tranny guy.. done deal.. smooth as silk.
Old Mar 13, 2009 | 02:33 PM
MrHeeltoe's Avatar
Former Sponsor
Check this out:
http://heeltoeauto.com/httech/YaBB.pl?num=1234511853
Bad axles you'd feel vibes on acceleration. You sounds like you have a balance issue.
Old Mar 16, 2009 | 08:11 PM
Etohprn247's Avatar
KoolKatz..
LOL goddamit! I wish I could read this first.. 3 wheel balancing still steering shaking >60, hubcentric rings (bought em' here AZ) still no difference, alignment....still shaking, spent $1K on coilovers hoping for bad shocks??? Hmmm reduction in wheel vibration BUT still there! (>60mph) AArrrgh! After some reasearch sounds like it can be my drive axles then? Shitt I could have put the couple thousands on down payment for another car! I basically stripp my car of aftermarket toys to make stock and buy lexus but then I really like the style of the 3rd gen TL. Pointless to get another TL and get similar headache! I have 42k miles currently, vibration started at 35k. Someone come steal it(insured)....lemme know I'll park it outside!
Old Mar 17, 2009 | 09:48 AM
Majofo's Avatar
lol.. How about you leave it parked in a secluded area.. we strip your car of all your parts and leave the frame.. I call dibs on the tranny & lamps.
Old Mar 17, 2009 | 04:59 PM
MrHeeltoe's Avatar
Former Sponsor
Shoulda called me!
You are going overboard though. The TL is a great car. You are nuts to think any other car might not have similar or even worse issues.
rockyboy
Aug 4, 2024 10:35 AM
Feb 25, 2020 09:57 AM
04tler
Sep 10, 2015 04:03 PM
thisisnotdave
4G TL Problems & Fixes
Sep 8, 2015 10:02 AM
MyKids&Cars
Sep 2, 2015 12:03 AM
