Steering Wheel- slight vibration at high speeds
Old Oct 7, 2008 | 03:58 PM
eagles7439's Avatar
6th Gear
I have a 2006 TL. I recently had my brakes changed and a vibration appeared in the steering wheel, very slight. It comes and goes and gets worse at some points. I had an alignment done and tire rotation and balance but the problem still persists. Has anybody else had this problem or any suggestions on how to fix it. Thanks
Old Oct 7, 2008 | 06:17 PM
Trew's Avatar
Remove the brakes and rotors and sand down the face of the hub, and the inside and outside of the rotor where the lug holes are.
See if that helps
Old Oct 7, 2008 | 11:05 PM
240sx acura tech's Avatar
acura master tech
does it happen when appling the brakes?
Old Oct 7, 2008 | 11:58 PM
eagles7439's Avatar
6th Gear
no it does not, i just recently had my brakes changed so they are solid, it just is a vibration when going around 75-85, when you hit the gas it goes away only when you are going those exact speeds
Old Oct 8, 2008 | 12:08 AM
Will Y.'s Avatar
Registered but harmless
It sounds like a wheel/tire balance issue- the balance is off. When the balancing was done, was it on a Road Force machine? It may be possible that one of the balance weights fell off too.
Quick way to check: switch front tires to rear and vice versa to see if the vibration is eliminated.
Old Oct 8, 2008 | 02:11 AM
YeuEmMaiMai's Avatar
rebalance the tires on the car or move them front to back and see if the problem goes away
Old Oct 9, 2008 | 09:33 AM
eagles7439's Avatar
6th Gear
okay cool thanks everyone, im gonna go get them rebalanced and rotated again and tell them to make sure to do it again hopefully that will fix the problem
Old Oct 9, 2008 | 10:26 PM
phatbastard's Avatar
could be a bent wheel as well.
Old Oct 10, 2008 | 07:00 AM
Trew's Avatar
oh sure, just ignore MY suggestion
Old Oct 10, 2008 | 12:41 PM
aliang01's Avatar
I , like many here at Azine have had the vibration issue at highway speeds (70+) and for the longest time that problem had zero solutions. Thought we tried everything...welll....here's the fix.
Get your tires off and send it to a Hunter Tire Balancer. It'll spin it at 100+ mph and check to see if they're straight. Balance them right and you'll be set. Probably is a good idea to do them to new tires just to be safe. Now, my TL-S drives perfectly at 80+ and braking is good too. Though....stock brembos do kind of fade braking at excessive speeds. (so don't try it or you'll be buying new rotors)
rockyboy
Aug 4, 2024 10:35 AM
peti1212
ILX
22
Jan 5, 2022 05:14 PM
Feb 25, 2020 09:57 AM
Sixers12
ILX
Sep 6, 2015 07:54 PM
