Steering Problems 06 TL
Old Jan 25, 2010 | 11:47 PM
LebaneseShowoff's Avatar
5th Gear
My friend has a 06 TL and it's hard to turn the wheel when the car is stopped, as i turn it left or right it gets harder to turn. He also told me he added power steering fluid, but he didn't put the recommended Honda/Acura fluid, i don't know if this affects anything.
The pump is not leaking and neither is the rack, i haven't worked on any TL's so i don't know if it is a common problem with these cars, i wanted to flush the system and add the proper fluid but i wanted to know if i can get some help/tips on here first, and i did try the search, all i get is iPhone and worthless info from the search, thanks.
Old Jan 26, 2010 | 08:40 AM
lylen's Avatar
I have a '06 too and I am kind of getting the same problem. The steering wheel is a little tight (in the morning while it's cold), and it makes a like a whining noise. I'm still trying to figure out what's wrong.
Old Jan 26, 2010 | 10:34 AM
5th Gear
On my friend's car the wheel gets stiffer as i turn left or right, the further i turn the wheel, the harder it gets.
Old Jan 26, 2010 | 10:36 AM
rockstar143's Avatar
There is a recall on the power steering assembly. My car used to make that crazy noise in the morning too.
Even if not leaking fluid...the steering being hard has to be related. Call the dealer with your VIN to make sure all recalls have been taken care of. It's covered and they'll usually loan you a car while they work on it.
It's not like my 91 civic hatch that had power assist and now power steering.
Old Jan 26, 2010 | 01:13 PM
lylen's Avatar
Description 04-08 TL POWER STEERING HOSE
Date
02/27/2008
Type
Recall Customer Letter
Status
Fixed
This is what it showed on the myacura site. Will they still fix it for free even though it's already been fixed?
Old Jan 26, 2010 | 04:13 PM
5th Gear
thanks a lot i'll have him call the dealership tomorrow morning.
Old Jan 27, 2010 | 05:16 PM
Well if it's still giving the same symptom I don't see how they could deny it. I'm sure they'll try but you can make it happen.
Old Jan 28, 2010 | 11:35 AM
Majofo's Avatar
Replace the inlet o-ring with the new orange one.. if that doesn't work you'll eventually need to replace the pump.
-->DIY - Power Steering Whine Fix<--
Old Jan 28, 2010 | 11:37 AM
lylen's Avatar
I just bought the inlet o-ring just the other day. I'm planning to change it out when i find a chance to.
Old Jan 28, 2010 | 04:34 PM
hondeducation's Avatar
i had the recall done at my acura dealership, but am suffering from this same symptom. it's normal steering about 75% of the time, but when i need to make a tight turn into a parking lot or parking space when slowing down, the steering wheel gets really tight and is tough to turn! maybe i should call acura back and see what's up. anyone else having problems AFTER the recall service??
Old Jan 28, 2010 | 04:41 PM
Majofo's Avatar
The TL has power assisted steering.. low speeds requires a little more effort, so I wouldn't worry about it. I suggest some dumbbell curls.
Here's a related thread:
https://acurazine.com/forums/showthread.php?p=11390484
Old Jan 28, 2010 | 08:02 PM
I hate cars's Avatar
It's normal for it to get a little harder. I'm guessing most people in this thead have never tried to park a car without power steering. Your forearms are in for a surprise.
If it's truly getting too hard, look for belt slippage or aerated fluid.
You stated you have the wrong fluid in there. Honda uses a thicker power steering fluid than other manufacturers and I believe it uses more zinc too. The pump may not be able to supply sufficient pressure at high load (turning while stopped) with the engine at idle rpms.
Next time verify by putting it in neutral and raise the rpms above idle and see if it lightens up.
And just so you know, you're not supposed to turn the wheel with the car stopped. It puts unnecessary stress on steering components and tire wear. Even a .5mph roll is much better than fully stopped.
Old Jan 28, 2010 | 08:11 PM
^^^Good info and tips. The answer lies here.
Old Jan 28, 2010 | 10:24 PM
suncityman's Avatar
Same thing happened to me, dealer replaced pump today, no problem anymore, turns great
Old Jan 30, 2010 | 01:13 PM
lylen's Avatar
I'm planning on calling Acura on monday to see if they'll do the recall for me for free. It's been done once already.
Old Jan 30, 2010 | 05:23 PM
vovka2007's Avatar
PS pump. Had on my 04. No noise, no whining, and no PS. Changed the pump works great.
Old Jan 31, 2010 | 06:12 PM
BGLEX81's Avatar
Same problem here....dealer replaced the pump, belts, hose and after 15k miles same problem again....Don't know what to do...Had them check the rack they said it prob not the problem ....They said it could be the tires....Really getting frustrating???....Any ideas???
Feb 25, 2020 09:57 AM
spidermankb
Mar 5, 2019 11:34 AM
marcelft
Jul 10, 2018 06:17 PM
EvilVirus
Dec 10, 2015 07:38 PM
jaynatlanta
5G TLX Problems & Fixes
Sep 15, 2015 11:08 AM
