Starter problem
Old Feb 4, 2016 | 09:35 AM
Nayramoney's Avatar
8th Gear
Starter problem
I purchased a 07 TL about, 2 weeks later the starter died on me, I tapped on it to get it started took it to my mechanic and ordered a new starter, I had all the fuses and cables checked, about 3 days with the new starter and I again couldn't start the car. again tapping on the starter started it up.I was told by the mechanic that it must be a defective part but I'm nervous that it could be something else, like I said there's no corrosion in cables or anything else that I can think of. Any thoughts as to what else it could possibly be
Old Feb 4, 2016 | 09:48 AM
Battery? Bad HFL unit can drain battery. Or it could just be a bad starter again. Not unheard of.
Old Feb 4, 2016 | 09:51 AM
Nayramoney's Avatar
8th Gear
I had the battery checked as well and it's fine
Old Feb 4, 2016 | 09:53 AM
NBP04TL4ME's Avatar
Stay Out Of the Left Lane
I would have the HFL unit checked as suggested, but if tapping on the starter gets you going, I'm guessing it's not the battery or the HFL. Your mechanic should replace the starter again no charge, assuming he stands behind his parts.
Old Feb 4, 2016 | 10:13 AM
Nayramoney's Avatar
8th Gear
Haven't had that checked yet, I'll look into it and yes he did replace it with no charge
Old Feb 5, 2016 | 07:03 AM
Turbonut's Avatar
If the starter was from one of the run of the mill aftermarket stores, probably junk. Better off purchasing a new starter, not necessarily from Honda/Acura, but one can be secured from a parts supplier.
RockAuto for example:
New $81-$135
Remanufactured $90-$129
Old Feb 5, 2016 | 12:30 PM
3rdGen's Avatar
Does/did the battery light come on?
Old Feb 6, 2016 | 07:40 AM
3rdGen's Avatar
Its could be a number of things. I'd begin with the HFL Unit, Starter, Battery, Alternator, Wiring. Check all of those then come back
-Battery
-Starter
-Alternator
-Bad Wires
-HFL Drain
Old Feb 8, 2016 | 01:43 PM
WDPanda's Avatar
The wire's leading to the starter has a common problem of becoming loose. Next time it doesn't start, try to play with only the connection and not tap the starter.
Old Feb 8, 2016 | 08:35 PM
Nayramoney's Avatar
8th Gear
Is there any way to fix that ?
Old Feb 8, 2016 | 08:37 PM
Nayramoney's Avatar
8th Gear
New $81-$135
So again the new starter that was put in died on me, should I consider buying an original Acura starter will it make a difference? Or am I just wasting my time and money?
Old Feb 9, 2016 | 07:57 PM
NBP04TL4ME's Avatar
- I would at the least ask your mechanic to get the next starter from a different supplier. That and/or ask for him to get an OEM one as Turbonut suggested.
What is your mechanic saying at this point?
Old Feb 10, 2016 | 01:57 PM
WDPanda's Avatar
You have to find a way under the battery to the starter and squeeze the connection if it has loosened itself. You can try squeezing with vice grips to give it a better grip.
Krisbo26
Apr 21, 2020 12:37 PM
neuronbob
3G RLX Problems & Fixes
Oct 20, 2019 02:55 AM
Evilocity
Apr 22, 2016 09:33 AM
TLMichelle
1G TL (1996-1998)
Jan 20, 2016 11:56 AM
JakeS
Jan 12, 2016 12:43 PM
