Start up issue
Old 07-29-2011, 05:22 PM
cbass's Avatar
Start up issue
ive had my 04 for about 2 years now and today i noticed that when starting the car it seems a little sluggish to start up. like its trying to hard to start. not sure how else to explain it. i feel like i have to hold the key longer for it to start. anyone have any ideas??
thanks. any help appreciated.
Old 07-29-2011, 09:30 PM
paperboy42190's Avatar
Received 1,162 Likes on 847 Posts
battery going out? classic symptom.
Old 07-30-2011, 01:55 PM
cbass's Avatar
seems simple. ill check it out.
Old 07-30-2011, 02:44 PM
JTS97Z28's Avatar
If it's cranking normally but just not firing like it used to then the issue lies elsewhere. If your battery was going out you should be able to tell by weak sounding or slow cranking.
Old 07-30-2011, 05:07 PM
csmeance's Avatar
Received 2,004 Likes on 1,424 Posts
How many miles are on the car?
Which gas are you using?
How old is the battery?
Do you make frequent short trips?
The car will start a bit rough (or stumble to start) if the wrong fuel is used, the battery is low or if the car isn't getting the right amount of fuel.
Also be sure that you hold the key in until the car starts! An easy way to elminate the potential problems is to do this:
Put in the key in the ignition and turn the car to position 2. Let the fuel gauge rise and stay there for a second. Then turn the car on.
If that solves the issue that means its a fuel issue! Doing this pressurizes the fuel system beforehand vs. quickly pressurizing and starting. To fix it, add some fuel cleaner Like Redline SI-1 and use top Tier fuel.
Old 08-03-2011, 09:49 AM
8th Gear
myvtec's Avatar
Hi, I have an 05 TL w/ NAVI and I'm the 2nd owner and have had the car for over a year and a half now.
Car also just passed 90K miles. I haven't had any starting problems with the car until 3 days ago. All of a sudden she's hesitating to start (to the point where I'm wondering if it will just NOT start one day really soon).
I've searched the forum and it seemed like there was a starting problems when the 3G's were newer, but I'm wondering if my issue is the starter or battery since it's older now and has some wear and tear on the parts.
Please help, don't want to leave the wife stranded.
Old 08-03-2011, 12:31 PM
csmeance's Avatar
The best thing to do is go to autozone and they will check your battery for free.
Old 08-03-2011, 01:51 PM
8th Gear
myvtec's Avatar
Good to know.
.....Does Pep Boys do this too? Anybody know for sure, I can always call if nobody knows.
Also, how much is a ....new battery? ..new starter?? (Just in case it is these parts)
Old 08-04-2011, 11:59 AM
cbass's Avatar
it was the battery. got it checked out at autozone. battery at walmart was $79.99.
myvtec (08-12-2011)
cycdaniel
12-17-2019 10:58 AM
Powder Monkey
2G CL Problems & Fixes
09-09-2018 12:55 AM
SilverJ
1/2G MDX (2001-2013)
09-21-2015 02:40 PM
ninersfgiantsfan
09-09-2015 01:14 PM
NSolace
09-03-2015 08:14 PM
Quick Reply: Start up issue
