Squealing belt
Old Jun 25, 2009 | 07:53 AM
zambo's Avatar
5th Gear
Squealing belt
Recently (about three months ago), I replaced the serpentine belt for squealing on startup. It looked chewed up and it went on without a hitch.
Now, it's doing it again, and I have to believe that there is something causing this to happen.
There seems to be a noise coming from what I believe is the tensioner.
Has anyone encountered this? If it is the tensioner, is there an DIY?
Old Jun 25, 2009 | 07:55 AM
InFaMouSLink's Avatar
Chapter Leader (NY/NJ)
did you change your pulley by any chance? mine is squeaking and replacement is on order. mine only squeaks when AC is on and im idleing so roughly 900-1400 RPMS.
Old Jun 25, 2009 | 07:57 AM
MichaelBenz's Avatar
CTS-V Import Slayer
Yes.....its one of three things....your idler pully....tensioner pully...or tensioner itself. You can buy all three together from your Acura dealer for under $100 if I recall...its a preassembled unit. That or figure out which pully is bad and just replace that one pully....thats even cheaper at $20-$30 per pully as I recall.
Note...search is your friend on this site....
https://acurazine.com/forums/3g-tl-problems-fixes-114/tensioner-pulley-686704/
Old Jun 25, 2009 | 08:23 AM
zambo's Avatar
5th Gear
Haven't replaced anything of the pully's or tensioner.
Is that fairly easy or a bit involved to replace?
Old Jun 25, 2009 | 08:29 AM
zambo's Avatar
5th Gear
I guess what I'm asking is if it's simply a bolt that I can remove with a breaker bar or do I need some impact tools?
Old Jun 25, 2009 | 08:40 AM
BradE's Avatar
The type of belt makes a difference to. I've had good luck with goodyear gatorbacks, they seem to strech out less than some other belts, over time.
Old Jun 25, 2009 | 10:49 AM
CTS-V Import Slayer
Yes...its simply a bolt on and fairly easy to do. If you follow the link I gave you...it has some basic how to info.
Old Jun 25, 2009 | 12:50 PM
01tl4tl's Avatar
basic tools and a good eye is needed
Get a new belt- dealer or Gates brand is well respected
get everything that goes with it for pulley or tensioner
High revving does a number on those parts- my AC belt tensioner started making noise at 45k miles and finally went at 80 (gen2 TL)
08KBP_VA
Oct 22, 2019 01:55 PM
brboy
Oct 5, 2015 11:34 AM
Jboat
Sep 30, 2015 10:58 AM
Boraxo
1/2G MDX (2001-2013)
Sep 29, 2015 04:35 PM
2ManyHobbies
Sep 24, 2015 09:23 PM
