Squealing belt
Squealing belt
Recently (about three months ago), I replaced the serpentine belt for squealing on startup. It looked chewed up and it went on without a hitch.
Now, it's doing it again, and I have to believe that there is something causing this to happen.
There seems to be a noise coming from what I believe is the tensioner.
Has anyone encountered this? If it is the tensioner, is there an DIY?
CTS-V Import Slayer
Yes.....its one of three things....your idler pully....tensioner pully...or tensioner itself. You can buy all three together from your Acura dealer for under $100 if I recall...its a preassembled unit. That or figure out which pully is bad and just replace that one pully....thats even cheaper at $20-$30 per pully as I recall.
Note...search is your friend on this site....
https://acurazine.com/forums/3g-tl-problems-fixes-114/tensioner-pulley-686704/
basic tools and a good eye is needed
Get a new belt- dealer or Gates brand is well respected
get everything that goes with it for pulley or tensioner
High revving does a number on those parts- my AC belt tensioner started making noise at 45k miles and finally went at 80 (gen2 TL)
