Speedometer Shorting when Engine Off
Old Nov 30, 2013 | 01:01 AM
jlicwinko's Avatar
Battery in my Acura TL 2005 died hard overnight. Could not determine the drain. New battery installed today. Tonight, found that with no key inserted, every 25 seconds the speedometer needle would click down (that is, the speedometer needle tries to rotate in the counter-clockwise direction) and at the same time, the memory set button for either seat one or two would flash on. This combination repeated every 25 seconds. I believe this is causing the battery drain. Can anyone explain why the speedometer needle would click down every 25 seconds with no key inserted? Just a note, I read that the HFL can cause battery to drain. My HFL died about two years ago and I will disconnect the power from it tomorrow (I am writing this at 2 AM). But I can't rationalize how the HFL might be causing the speedometer needle to click down. Thanks for your thoughts and advice.
Old Dec 2, 2013 | 12:12 PM
LoveMyTL-S's Avatar
Anyone?
Old Dec 5, 2013 | 11:32 AM
jlicwinko's Avatar
Just checking in. As a favor, could anyone with a 2005 Acura TL check their speedometer with no key in the ignition and see if the needle on the speedometer clicks down about every 30 seconds or so? I know this is a strange request, but thanks. Maybe it is normal?
Old Dec 5, 2013 | 11:39 AM
paperboy42190's Avatar
I'd check for you right now but mine is a 2007 type S, not sure if it would exhibits the same characteristics. However I don't think that should be considered normal....
Have you disconnected the hfl? And is it still draining your battery?
cycdaniel
Dec 17, 2019 10:58 AM
BoricuaTL
Apr 8, 2016 01:08 PM
Sep 17, 2015 08:57 PM
Sep 15, 2015 06:44 PM
