Steering Wheel Lights
Old Jun 21, 2009 | 09:06 PM
ladiesman217's Avatar
e92 335i
Alright so i'm having a slight problem with my steering wheel buttons. They will not illuminate anymore, a month and a half ago my cruise control side buttons burnt out with the exception of the cruise button, now yesterday my "mode" button wont illuminate either. It looks like the volume and channel buttons are about to die out as well as they illuminate only a faint green colour, very different from the rest of the other buttons as they are much lighter. What is also very weird is that the handsfree link buttons and voice command buttons are starting to faint as well. The rest of the buttons in the car as they illuminate as they are supposed to. When I first went to the dealership to get the mode button fixed, they said they would not cover it as the warranty for interior lights is 1 year / 20 000 km. They wanted $400 to replace it. Enough said, so i decided against getting the mode button replaced. Now that the other buttons are starting to die out im getting more and more irritated. What should i do? Is this a common problem for my 2006 TL with only 64k km? Why is this only happening on my steering wheel? The sight of my steering wheel lights dying out / not illuminating is starting to greatly annoy me, im sure most of you would agree if you all had the same problem. Any insight to this problem would be much appreciated. Thanks.
Old Jun 28, 2009 | 10:47 AM
NE14RoxCJ's Avatar
Not sure why they would burn out unless they are on ALL the time. Do you drive with your lights on during the day?? I would suspect the bulbs, since they didn't all stop working at the same time. I just replaced the bulb in the volume switch on mine. The reason they wanna charge so much is that the Air-bag assembly has to be removed. Still not that hard. The bulbs are kinda pricey as far as bulbs go. I think the one I replaced was ~$3.50. The air-bag is held in with two big T30 torx-head bolts. It is wise to disable the SRS system to avoid popping the bag, but I never disconnected mine. Just took the screws out and worked the switch connector out from under the air-bag. The bulbs snap into the back of the switch assembly. I wish I was close by. I'd do the job for half that. HAHA. $400!! That's highway robbery. $12 in bulbs and $388 labor?? I'm in the wrong biz...
Old Aug 2, 2009 | 09:22 PM
CMCx2009's Avatar
To the "t" I have the same exact problem! I am contemplating getting a Type S wheel anyway! It should be good to go out of the box, I would imagine
Old Aug 3, 2009 | 07:47 AM
dwb993's Avatar
Try another dealer---these should be covered under warranty. You may also want to contact Acura Corporate to get their ruling. Alternately, you can replace them yourself---it is not difficult to do at all:
https://acurazine.com/forums/3g-tl-2004-2008-93/steering-wheel-lights-went-out-car-dealer-686268/
Old Aug 3, 2009 | 07:51 AM
dwb993's Avatar
^^ Post #38 in that link has instructions to replace steering wheel lights.
Old Aug 4, 2009 | 09:56 PM
NTICED's Avatar
Darryl
i have this problem but its not my wheel its my heated seats light only on the driver side my car is an 06 TL with only 26K miles i think thats rediculous i havent tried to get it fixed yet
Old Aug 22, 2009 | 05:33 PM
zsameer's Avatar
First i had one of the heated seat lights out once i fixed that the otherone went out. Luckily that happened while i still had everything apart so i replaced the other one too. Then i noticed the Mode button light on the steering wheel was out . I kept telling myself its no big deal since i didnt wanna have to take off the airbag to fix one bulb but it pissed me off everytime i looked at it so today i finally took the air bag out and replaced all the light bulbs there were a total of six i think. I bought the mini 12v lamps at radio shack for 1.79 for 2 so the bulbs were 6 bucks and locktight for another 6 so for $12.00 i replaced all the steering wheel lights... took me less than an hr. Hope these bilbs will last longer than the crappy honda bulbs. Thanks to everyone at Acurazine for great DIYs.
Old Sep 24, 2009 | 02:58 PM
shtewps's Avatar
'06 TL | WDP/Ebony +Nav
Hey would you happen to have a part# for the mini lamps?? Right now I am going to replace the mode light but if any others go out I would love to try other lights that would potentially last longer. Thanks!
Old Sep 24, 2009 | 03:26 PM
erick3's Avatar
i have the same problem....my mode button went out.
my heated seat light went out at one point, but after smacking it around one time...it came back on (for good)
Old Sep 24, 2009 | 07:25 PM
Pureadrenaline's Avatar
My zoom button went out the other day on the dash under the nav screen and on the steering wheel the cruise button and the hang up button is out? What is the fix for the zoom button?
Old Apr 24, 2010 | 10:27 AM
wps007's Avatar
mini bulb number
Old May 26, 2010 | 08:39 AM
mrsimeon's Avatar
I have a few lights out in my interior as well.
The cruise controll is not lit.
On the dash were ther trip and function button live are both out.
and the Heated seats both sides are out. BUT when the seats are activated the RED Led does work,
Just the Indicator leds are out.
Hard to do things in the car when you first buy it and I am still getting used to the interior.
bought my 2004 TL May 24, only 2 days.
any other recommendations on how to do the dash leds and the center console ?
Old May 26, 2010 | 08:47 AM
rockstar143's Avatar
Oddly enough mine seem to go out sometimes and not others...maybe just corrosion over time, I've tapped on the heated seat one and it will sometimes come back. Either way, for some reason I don't sweat it too much. I guess eventually, when enough go out I'll give the DIY a whirl.
Old May 26, 2010 | 04:34 PM
dwb993's Avatar
DIYs for all of these lights are in the 3G Garage here:
https://acurazine.com/forums/3g-tl-2004-2008-93/3g-tl-service-department-aka-garage-questions-answers-check-here-first-553557/
Old May 26, 2010 | 04:51 PM
db, I've noticed...
you're quite helpful. I guess when it bothers me enough i'll tackle this too.
Old May 26, 2010 | 05:12 PM
dwb993's Avatar
It really is not that difficult, especially with the pics and instructions in the DIY. The car comes apart like a Lego toy!
Old Jul 16, 2010 | 10:11 PM
cjTL's Avatar
I'm Craig
Sorry for this bump...
But two of my damn lights around my navi screen went out tonight. The "Dual" button and the "Off" button for the climate control.
A) I've read through that guy's DIY and couldn't seem to find how to take the stuff apart.
B) How much would the dealer nail me for replacing these bulbs?
C) Could it be a fuse if they went out at the same time?
Old Jul 28, 2010 | 02:32 PM
TLSkier's Avatar
My phone call button light went out...dealer said, "let us replace ALL the lights in the steering wheel, as sooner or later, your car is now five years old, others may go". $160 parts & labor; Curry Acura, Scarsdale, NY. Everything's perfect now. Good luck.
Old Jul 28, 2010 | 04:26 PM
cjTL's Avatar
I'm Craig
I replaced all the bulbs I'd mentioned in my previous post. It was about $65 including shipping for the 15ish bulbs I replaced. And free labor.
Old Aug 2, 2010 | 09:32 AM
dmassott's Avatar
Detail Cars in Philly in
my bro just got a certified 06 tl and 4 months later a bunch of the dash lights are out and the steering wheel lights come on and off. Took it back to the dealer and they wanted $200 to replace them. effed up that you buy a car certifed and this happens.
then call corporate and they say you are effed.
Old Aug 2, 2010 | 10:22 AM
dwb993's Avatar
Tell him to save the money and do it himself!
Old Aug 4, 2010 | 02:21 PM
dmassott's Avatar
we bitched to the general manager of the dealership and now they are going to replace them for free
Old Aug 4, 2010 | 06:10 PM
pwr2panda's Avatar
I think the culprit could also be locking/unlocking the car...if you use that feature alot, it turns on/off all those interior bulbs...dont know why they did it taht way.
Old Aug 6, 2010 | 05:19 AM
TLmaster7's Avatar
PJKTL1
I think they happen to all TLs, same problem happen to me and my two other buddies
Old Dec 5, 2013 | 02:30 PM
sandifordpat's Avatar
4 screw 1 hour later fixed you can purchase bulbs through newark electronics on light pack of ten was $12.00 just unwrap old light from base and remove blue cover from old light I did all the lights at one time really simple
Jui
Feb 25, 2020 09:57 AM
SpraykwoN
ILX
Sep 11, 2015 08:45 PM
pesobreeze
1G RL (1996-2004)
Sep 3, 2015 12:26 PM
MyKids&Cars
Sep 2, 2015 12:03 AM
