Speedometer Behaving Like Tachometer
Old Jan 23, 2019 | 09:23 PM
Kenny's TL's Avatar
6th Gear
I have a 2004 TL manual transmission.
Just had the original clutch replaced at 237,000 miles.
Before I replaced the clutch, the speedometer started behaving like the tachometer.
It's also doing it with the new clutch.
It goes up and down as I change gears. It also wobbles around the speed I am going.
I noticed it does it more when either the car is cold or it's cold outside.
Every once in a while it behaves normally.
Any suggestions as to what is going on?
Old Jan 28, 2019 | 12:14 PM
KaMLuNg's Avatar
VSS? have you checked this? any check engine lights?
cheekoo
Oct 5, 2012 07:41 PM
mohamed.ali24
May 11, 2009 11:04 PM
carlos gonzales
Apr 6, 2006 01:31 AM
Hou-RL
Aug 17, 2005 06:09 PM
