Speedometer Behaving Like Tachometer
I have a 2004 TL manual transmission.
Just had the original clutch replaced at 237,000 miles. Before I replaced the clutch, the speedometer started behaving like the tachometer. It's also doing it with the new clutch. It goes up and down as I change gears. It also wobbles around the speed I am going. I noticed it does it more when either the car is cold or it's cold outside. Every once in a while it behaves normally. Any suggestions as to what is going on? |
VSS? have you checked this? any check engine lights?
