Sound from driver side front end after changing rack and pinion
Old May 21, 2026 | 04:10 PM
Makent's Avatar
3rd Gear
This sound started after replacing the rack and pinion. It only happens at 3k rpm and under heavy acceleration.
here is a link to my Reddit post with the video for the sound.
https://www.reddit.com/r/AcuraTL/s/7eOLG1CPnj
Old May 22, 2026 | 07:16 AM
twokexlv6coupe's Avatar
You needed to drop the entire sub-frame to change out the rack, correct? That is a BIG job, you could've missed anything reinstalling everything. Time to look over 100% of everything you touched for that job.
It honestly sounds like a heat shield of some sort rattling. Exhaust, rotor dust shield, etc
Old May 22, 2026 | 07:29 AM
Makent's Avatar
3rd Gear
I removed the rear subframe bolts completely and lowered the front ones. I had to replace the mid subframe mounts while at it as they were split in half. I’ll jack it back up this weekend when I’m off and take a look. But other than this one scraping sound there isn’t any other issue. No play in the wheel, no bumps or creaks.
Old May 22, 2026 | 12:48 PM
csmeance's Avatar
check all your bolts such as motor mounts, sway bar links, etc. Verify everything is tight before jumping to the parts cannon!
Also, I'm not sure what mid-subframe mounts you mention, but most of them need to be pointing in a certain direction or installed in a particular way to avoid clunks! For example LCA bushings have arrows pointing to what direction they need to be installed in.
MickyQ
Apr 9, 2018 09:14 PM
Mr.Tea
1/2G MDX (2001-2013)
19
Feb 12, 2016 02:12 PM
