smoked tail lights
Old Mar 30, 2010 | 07:27 PM
NyAcUrATL08's Avatar
smoked tail lights
I got my tail lights smoked with spray. My car is leased. Is it possible to remove the spray? Thanks
Old Mar 30, 2010 | 07:31 PM
TLin401's Avatar
'13 Hyundai Sonata
Try rubbing alcohol. I know the spray that I use can be removed with rubbing alcohol.
If nothing, then try taking the lights out and using paint stripper.
Old Mar 30, 2010 | 07:39 PM
Dat Boi Ralph's Avatar
2004 SSM FTMFW !!!!
If I'm not mistaken also WD-40 works but not 100% sure, it wont hurt to try
Old Mar 30, 2010 | 07:58 PM
2004 SSM FTMFW !!!!
^ my bad its break cleaner that works on removing smoked spray
Old Mar 31, 2010 | 01:26 AM
Takoyaki's Avatar
Depends on the spray but mine came off by putting a tape over the tinted part and ripping it off
Old Mar 31, 2010 | 10:20 AM
AMUA6's Avatar
ScoobyZINE
If it's the VHT Nightshadez, try using the dupli-color lacquer thinner. Or any type of cleaner wax with some elbow grease put into it. i removed it pretty easy from my headlights.
Old Mar 31, 2010 | 10:34 AM
swoosh's Avatar
takin care of Business in
remember to take the lights off the car before you do anything....next thing u know if ur touching up paint on ur bumper
Old Mar 31, 2010 | 11:32 AM
powerflow's Avatar
Wiggy Wiggy Wiggy
Be careful with strong solvents on plastic. Test a small corner area first. You probably will need to run over the lens with a polisher.
Certain strong solvents can fuck up the plastic in no time.
Old Apr 4, 2010 | 07:52 PM
twistdtl's Avatar
7th Gear
Find out what kind of spray was used. If it was automotive paint and they were done proper it will not come off with chemicals. Paint stripper will ruin the plastic, I would be hesitant to try anything until you find out what was used.
BoricuaTL
Apr 8, 2016 01:08 PM
handsom-hustla
Nov 13, 2015 05:04 PM
wusty23jd
Sep 24, 2015 11:41 AM
Ny1718
Sep 11, 2015 09:21 AM
brjones9
Sep 3, 2015 07:30 PM
