Side Mirror Judders When In Reverse
Old Oct 21, 2008 | 10:53 AM
poolmon's Avatar
My passenger side mirror just started juddering (shaking) when I put the car it in reverse. The mirror is supposed to lower itself to see the curb when backing up and it used to. Now itsjudders for up to 30 seconds before finally stopping. I heard there is a sinent recall on this. Anyone know about this problem?
Old Oct 21, 2008 | 02:16 PM
csmeance's Avatar
its a common issue, go to your dealer and they will replace the mirror assembly for you.
Old Oct 21, 2008 | 02:55 PM
Miisz Chelly's Avatar
Filipina
I recently have been having the same problem
Old Oct 21, 2008 | 03:26 PM
Trew's Avatar
Try this link guys Possible free fix...
https://acurazine.com/forums/showthr...t=side+mirrors
(I have a soft spot for Filipina chicks)
Old Oct 21, 2008 | 03:29 PM
TeknoKing's Avatar
I have the same problem.... but I can't make it to the dealer...I absolutely have no free time.
08 TL-S
Old Oct 21, 2008 | 09:41 PM
RACINGHART03's Avatar
Free actuator replacement for those of you under warranty. Regular old spray white lube for those of you who arent. Angle the mirrror so you can get the little red tube back behind the mirror and give the posts a good douching. Should do the trick (at least for a while)
Old Oct 22, 2008 | 08:36 AM
Filipina
Thanks for the thread and for the compliment. Filipina's are the way to go :wink:
Old Oct 22, 2008 | 10:10 AM
playa4real's Avatar
i got this problem too looks like ill be making a trip to the dealer.
Indian chicks are the way to go however i don't discriminate against any good looking girl
Old Oct 22, 2008 | 10:23 AM
nim090's Avatar
Yeah I have an 07 TL-S, they replaced my actuators under warranty...working perfectly fine now.
Old Oct 22, 2008 | 03:30 PM
Trew's Avatar
Have any of you tried doing what KINEMATRIX suggested in that thread? It worked for a few people. No money or hassle involved.
Yea that's what my filipina wife said before I married her. So I took her word for it
Old Oct 22, 2008 | 03:38 PM
CarrieLynn's Avatar
WOW, this just happend on my car last weekend.....I'll try to lube it up
Old Oct 22, 2008 | 06:26 PM
Free is good!!
Old Oct 22, 2008 | 06:35 PM
playa4real's Avatar
went to the dealer today...
the tech came out and just moved the mirror (using the button) all the way up, then all the way down, all the way right, all the way left. This didn't work the first time, but he did it a few more times and it worked.
Old Oct 22, 2008 | 06:45 PM
Trew's Avatar
Did he say "Abra-Cadabra" before he pushed the button? If he did, I can believe that fixed it!
Old Oct 22, 2008 | 06:56 PM
Tripnbeats's Avatar
if its the crack crack crack crack noise the threads are shot on the backside of the mirror...if u still have warranty get it done. they did both of mine... when it happened the drivers side mirror had rust in it. it was eating through the reflective material.
Old Oct 22, 2008 | 07:05 PM
playa4real's Avatar
How'd you know?!
yeah i was trying to get mine replaced and he was ready to do so, but then he was like actually let me try it a couple more times and somehow he got it to work. i didnt really feel like pushing them on the issue as I was there to get an estimate for the scratch/dent I got from a couple of weekends ago. in any case, i know what they did is a temp. solution, so i'll just wait for it to start juddering again (probably before the end of the week) before i go back and complain
Old Oct 22, 2008 | 07:11 PM
Trew's Avatar
I hope they at least documented the issue on your invoice... This way they might consider goodwilling it if it acts up again and your warranty has expired.
Old Oct 22, 2008 | 09:05 PM
This may work. Moves the actuator pins to locations they dont see often are picks up some fresh lube which in turn stops the juddering. Lemme know how long it lasts. I like it. Just curious to see how long it lasts. See even us know it alls can learn a thing or two. < That ones for me!
Old Oct 23, 2008 | 08:26 AM
Filipina
I pushed my side mirror up until it clicked a few times and then down until it clicked..works just fine now. We'll see how long it'll hold until I'll have to go to the dealer...
Old Mar 4, 2009 | 11:03 AM
playa4real's Avatar
update
How'd you know?!
well this started happening again a few weeks ago. im a little disappointed, but by the method they attempted to fix the issue its understandable. looks like there is now a service bulletin out (Feb 09) that *indirectly* states to replace just the actuators. will have to go to the dealer for this.
Old Mar 5, 2009 | 03:08 PM
imj0257's Avatar
Q('.')=O
i have this issue of my driver side mirror juddering but only when i unlock my car. it's like it moves the mirror back in its preset place, even though i never moved it in the first place lol.
Old Mar 5, 2009 | 03:20 PM
Elegant TYPE S's Avatar
Being an Acha Bacha in
I did this exact thing a few weeks ago and it fixed my problem as well without having to take a trip to the useless dealer. Forgot to post back up so that others can know that this worked for me.
Old Mar 5, 2009 | 03:27 PM
imj0257's Avatar
Q('.')=O
^hmmm will have to try that
Old Nov 9, 2009 | 01:31 PM
TonemanTLS's Avatar
LUV MY 2007 CBP TLS
Damn i have the same problem but my warranty is expired due to Mileage, so i will try the moving trick and see if it works and i will let you guys know... thanks for the tip!
Old Nov 9, 2009 | 02:02 PM
coykiam's Avatar
I have this problem in my 06, currently at 30K miles and it actually started happening around 10k miles. I just thought it wasn't a big deal till I saw this thread. I might try this, if not im gonna raise hell at the dealer to replace it...lol..hehe nah im a nice guy...but will try this fix...thanks guys
Old Nov 9, 2009 | 03:39 PM
Paintballny's Avatar
TL
I had this problem when I first got my cpo tl... Did the same thing myself and haven't had an issue since. Give it a try if you're having the issue.
Old Nov 10, 2009 | 11:48 AM
Dan1629's Avatar
Registered Member
mine did it also. I just ran the mirror up and down a few times hasnt happened again been like a year already
Old Nov 10, 2009 | 03:09 PM
TonemanTLS's Avatar
LUV MY 2007 CBP TLS
yup, did the moving up and down thing this morning and the juddering stopped don't know how long it will last but previous post said a year so that's cool...
Old Nov 10, 2009 | 03:18 PM
Izzy-Type-S's Avatar
WOT in the new ATLP V2s!
Same here, didnt know that was a thing i could use the warranty for just thought it was the position i have saved for myself and it touching the bottom. also i have a vibrating broken speaker.
Old Nov 10, 2009 | 03:19 PM
...& thats why I dated 3 of them in college
Old Nov 11, 2009 | 03:41 PM
Yonkers914's Avatar
04Tl
I had the same problem on my 2003 TL and WD-40 fix'ed them right up. My 04 Tl is having the same exact problem now and WD-40 ain't working lol and i cant take the car into the dealer and get it replaced under warranty cause i upgraded them to 07 blinking mirrors and there not original!! SUCK'S
Old Nov 11, 2009 | 06:19 PM
olrac1's Avatar
Worked for me i just went out and tried it .The mirror operates much smoother I recommend any one who has this issue to at least give the up, down, left ,right method a try it took all of three minutes to fix.And to think I've been thinking about ordering a replacent mirror off of ebay I am glad this topic came up. I just hope that the fix lasts. Thanks Aziner's the forum fixes yet another issue saving me a trip to the dealership.
Old Nov 12, 2009 | 09:40 AM
jmkiang's Avatar
zaino'd
Ah a fix! Nice.
Old Nov 12, 2009 | 09:56 AM
94eg!'s Avatar
#1 Super Guy!
It's caused by dust getting caked on the grease for the control rods. This causes them to jam up. The actuator has torque overload protection and that's the "click click" sound your hearing. This keeps the parts from breaking if the mirror gets stuck or someone simply pushes on it with their fingers. No the gears are not stripping, no parts are not breaking.
Moving the mirror back & forth in all directions scrapes the dust off and shifts the lube around making it smooth again.
This will always happen again later, but it's not a big deal. Just move the mirror in opposite directions and it will come back to life...
rockyboy
Aug 4, 2024 10:35 AM
Type S Zero
Feb 17, 2016 02:37 PM
sockr1
Oct 1, 2015 01:31 AM
hand123
Sep 10, 2015 09:27 AM
