Shootin' spark plug
Shootin' spark plug
This morning my spark plug shot out the engine and through the coil. Replaced both the plug and coil. A few mins ago same thing happened same cylinder. WTF is happening?!
HEAVY_RL (09-15-2012)
the weird thing is the new plug wouldnt tighten up in that cylinder so I took one from another cylinder and it went in fine. I need to know why this is happening in the first place in the same cylinder?
threads are gone! it can be repaired without removing the head but it takes skill and experience. make sure you have that available, or pull the head.
Over time, the spark plugs get loose and/or poor assembly from the plant.
When they get loose, what usually happens is the combustion gasses go up into the threads and fuses the spark plug to the head and when you go to pull out the plug. You'll pull the threads along with the plug if you're not patient.
The plug shooting out is a little more rare to see but it happens. So take out all the coils and check the other spark plugs to see if they're tight, unless the dealer does it for you.
acuratl26
04-23-2020 07:30 PM
ITSJESTER
17
12-06-2018 02:29 AM
Joe Avesyan
09-29-2015 03:57 PM
