Shift lock.. No Navi or Radio HELP!!!
Old Aug 5, 2008 | 12:34 PM
mkjrn64@gmail.com's Avatar
4th Gear
Hey Guys, I have a 06' Nighthawk black TL 5AT w/ Nav with 38,000 miles. Last night when i was driving, i pulled up to a gas station and i went to put the shifter into P and realized that the shifter was stuck and couldn't go pass Neutral . So i opened up the drivers manual and it said i was in shift lock and i had to turn off the car.. use the key in the slot near the shifter to move it. I did that and shifted into P. Yet when i turned the car on, The Radio+ Nav screen were off..the temperature screen was on but no text and my 12V output where i attach my radar detector was off too. I dont think its a tranny problem cuz I turned it on and shifted [with my house key in the shift key slot] and the car still function properly [so i could get home at least]. I read up on other forums that it may be a brake switch, but why would it affect my Nav+radio and 12V? I checked and the brake still works. Could it be a fuse? My friends also think that my aftermarket sub could have shorted something out..maybe fuse related..Could someone pls help?
Old Aug 5, 2008 | 12:35 PM
4th Gear
brake lights still works^
Old Aug 5, 2008 | 12:58 PM
csmeance's Avatar
check your fuses, I think its fuse 32 that can cause all of this...
Old Aug 5, 2008 | 01:12 PM
4th Gear
alright ill go check the fuses.
Old Aug 7, 2008 | 02:01 PM
4th Gear
yeah man it worksss thanks..sorry for the late post
Old Aug 7, 2008 | 05:39 PM
csmeance's Avatar
no problemo, good to see that you got it working
Old May 26, 2009 | 04:09 AM
dred87's Avatar
so what was the solution to this problem?
I just got this problem myself. My car would not start
so I checked my battery and somehow my ground was lose, so i connected it and then this problem is occurring, I do not know how to fix it..help
Old May 26, 2009 | 08:06 AM
dred87's Avatar
well im not sure which of the two things i did fixed it, but heres what i did:
i added a fuse to the empty #32 slot in my fuse box
changed both fuses on my add a circuit for slot #31
and disconnected both terminals on my battery for about two minutes...violla works like a charm.
this problem happened to me because i changed my battery to a yellow top(which kinda doesnt fit very well), my ground wire came loose and i found out last night when i tried to turn my car on...thx anyways guys.
4drviper
Apr 23, 2025 07:13 PM
SidhuSaaB
May 30, 2020 12:40 AM
SinCityTLX
20
Oct 19, 2015 11:23 AM
jdmaszfcuk
Oct 19, 2015 12:31 AM
Cgannotti
Sep 25, 2015 05:04 PM
