Shift lever shaking !
Old Jan 8, 2012 | 09:22 AM
ABP_04TL's Avatar
6-SPEED LOVER
Exclamation Shift lever shaking !
I still havent solved my vibration issue, I've changed my driver axle to OEM, still debating on my Passenger side or my half shaft bearing... My mounts r good no issues with them.
So what I feel is when at 3rd or 4th gear around 3-4RPM my front vibrates and shift levers shakes forward and backwards... Has any1 experience this before?
Help is appreciated thnx every1
Old Jan 11, 2012 | 05:20 AM
04Redondocolorado's Avatar
B A N N E D
Could be your shaft bearings or tire balance lol but I think your headed in the right direction with goin back to stock to eliminate them from being a possibility. Goodluck
Old Jan 28, 2012 | 01:08 PM
EATSLEEPRACE's Avatar
6SPEED FEVER
I changed both my axles..problem solved
Old Jan 28, 2012 | 01:55 PM
paperboy42190's Avatar
how are you 100% sure your mounts are good? sometimes the signs of worn mounts are more subtle than you think.
this is what happened to my front motor mount, and i didnt even feel much increased vibrations in the cabin, if at all:
Old Jan 29, 2012 | 11:45 AM
ABP_04TL's Avatar
6-SPEED LOVER
So both axles are brand new OEM! Vibration gone.... i have Innovative mounts paperboy...
Now im getting this wierd thump when releasing clutch at 0 MPH on my right pas side, could it be my Links? or LCA?
SidhuSaaB
May 30, 2020 12:40 AM
Popee
Dec 20, 2015 12:08 AM
prbori
Sep 27, 2015 01:37 AM
mellsonnj
Sep 24, 2015 04:42 PM
Hines57
Sep 24, 2015 01:58 PM
