Shift lever shaking !
I still havent solved my vibration issue, I've changed my driver axle to OEM, still debating on my Passenger side or my half shaft bearing... My mounts r good no issues with them.
So what I feel is when at 3rd or 4th gear around 3-4RPM my front vibrates and shift levers shakes forward and backwards... Has any1 experience this before?
Help is appreciated thnx every1
how are you 100% sure your mounts are good? sometimes the signs of worn mounts are more subtle than you think.
this is what happened to my front motor mount, and i didnt even feel much increased vibrations in the cabin, if at all:
So both axles are brand new OEM! Vibration gone.... i have Innovative mounts paperboy...
Now im getting this wierd thump when releasing clutch at 0 MPH on my right pas side, could it be my Links? or LCA?
SidhuSaaB
May 30, 2020 12:40 AM
Hines57
Sep 24, 2015 01:58 PM
