Several Interior Lights Out
My 04 has several interior lights out.
1. Heated seat switch, switch works, just no light.
2. Lights on the right side of the steering wheel cruise controls
3. Some of the lights on the left side of the steering wheel
4. Shift indicator
How are these replaced?
4. Shift indicator
Just buy the bulbs and replace them.
http://www.acuraoemparts.com/delray/...All&vinsrch=no
The bulbs screw in and screw out kinda.
Getting to the bulbs is the hardest part.
Check out the 3G garage sticky =)
2016 Acura TLX
I've got pretty much the same lights out as the OP. How much would you think the dealer would charge to replace them? I've replaced interior lights before so I can probably do it myself over winter break, but I'm not too sure about taking out the airbag. Then again, I have taken a digital odometer out to replace the backlight on my dad's odyssey.
Early Shifter
i have this problem as well. i just bought the car under a week now and just spending this winter replacing/changing all the things to bring it back to norm....
i noticed a few of my lights are out like the OP. even a few of the lights along the side of the nav screen.....
arrghhh....seems like a whole days worth of carefully removing trims and switches....oh well......
takin care of Business in
Received 4,732 Likes
here is the DIY to replacing it:
Dont thank me....Thank DeathMetal for writing these DIY's
https://acurazine.com/forums/3g-tl-2004-2008-93/g-100-diy-led-interior-conversion-part-0-retrofit-oem-bayonet-housings-led-747846/ - Part 0 Retrofit of OE Bayonet Housings with an LED
https://acurazine.com/forums/3g-tl-2004-2008-93/g-100-diy-led-interior-conversion-part-i-map-light-console-746609/ - Part 1 Map Light Console
https://acurazine.com/forums/3g-tl-2004-2008-93/g-100-diy-led-interior-conversion-part-ii-rear-door-window-switch-w-handle-leds-746947/ - Part 2 Rear Door Window Switch w/ Handle LEDs
https://acurazine.com/forums/3g-tl-2004-2008-93/g-100-diy-led-interior-part-iii-steering-wheel-leds-audio-cruise-modules-763640/ - Part 3 Steering Wheel LEDs (Audio and Cruise Modules)
https://acurazine.com/forums/3g-tl-2004-2008-93/g-100-diy-led-interior-conversion-part-iii-steering-wheel-746972/ - Part 3 Overview
https://acurazine.com/forums/3g-tl-2004-2008-93/g-100-diy-led-interior-conversion-part-iv-center-vents-747870/ - Part 4 Center Vents
https://acurazine.com/forums/3g-tl-2004-2008-93/g-100-diy-led-interior-conversion-part-v-cluster-console-easiest-bunch-747874/ - Part 5 Cluster Console (EASIEST OF THE BUNCH!)
https://acurazine.com/forums/3g-tl-2004-2008-93/g-100-diy-led-interior-part-vi-front-passenger-door-w-rl-door-handle-led-750657/ - Part 6 Front Passenger Door w/ RL Door-Handle LED
https://acurazine.com/forums/3g-tl-2004-2008-93/g-100-diy-led-interior-part-vii-front-driver-door-w-rl-door-handle-led-750671/ - Part 7: Front Driver Door w/ RL Door-Handle LED
https://acurazine.com/forums/3g-tl-2004-2008-93/g-100-diy-led-interior-part-viii-knee-panel-lights-vsa-mirror-etc-750880/ - Part 8: Knee Panel Lights (VSA, Mirror, etc)
https://acurazine.com/forums/3g-tl-2004-2008-93/g-100-diy-led-interior-part-ix-heated-seat-switches-755070/ - Part 9: Heated Seat Switches
https://acurazine.com/forums/3g-tl-2004-2008-93/g-100-diy-led-interior-part-x-cupholder-illumination-755388/ - Part 10: Cupholder Illumination!
I have several bulbs out on my back lighting on my seat heaters, VSA and steering wheel cruse control. I just replaced the ones on the steering wheel. it was a peace of cake. make sure you disconnect the car battery first it's dangerous to work with airbags and the battery connected. then on both sides of your steering wheel airbag there are 2 phillips screws one on each side. remove them and pull the airbag out then you can remove the screws for which ever switch panel you have bulbs out and replace them. I'm still trying to figure how to get my other bulbs replaced.
handsom-hustla
11-13-2015 05:04 PM
oyayjoe
09-12-2015 04:40 PM
