Seat memory is not adjusting
Old Apr 2, 2020 | 07:40 PM
firebolt's Avatar
Lightbulb Seat memory is not adjusting
Hi!
I've just gotten my door lock actuator replaced. Finally! A was so glad! But now I have another problem. I can't change the seat memory. I press MEMO, hear 1 beep, press and hold #1 button and nothing happens! Neither #1 nor #2. But I use #1 remote.
So, finally I can use my remote to open/close the doors, but when I open it, the seat move to #1 position in its memory! Ooooh! After it stops moving the green indicator on the #1 button is on.
What's wrong with my MEMORY system? How to fix it?
Old Apr 2, 2020 | 07:42 PM
truonghthe's Avatar
to set the memory seat, press memory the press and release the number that relate to your key fob.
Old Apr 2, 2020 | 07:48 PM
firebolt's Avatar
But if it doesn't work? I press and hold, I press and release. In manual they said to hold until I hear two beeps. But whatever I do it doesn't do two beeps.
Old Apr 2, 2020 | 07:52 PM
truonghthe's Avatar
Press the memory button, there should be a beep, green light on 1 and 2 should flash. Then you press whatever number after that it beep again.
Old Apr 2, 2020 | 08:13 PM
firebolt's Avatar
Yes, absolutely true! I've just walked to my car and made a short video about how it doesn't work this way. But after I made a video I did next. I pushed open and close buttons on the remote to disconnect it from the car system. And after I did that I pressed MEMO and #2 button. And I heard two beeps! Yes, I kept seat position for remote #2! But I can't do it for #1 remote.
Old Apr 2, 2020 | 11:55 PM
Midnight Mystery's Avatar
Null and proud of it
Mine would stop working intermittently... Check your mirror actuators.
Old Apr 3, 2020 | 01:23 AM
firebolt's Avatar
Once again please. When I open the doors with remote #1, seat and mirrors are moving to the position keeping in its memory. Why should I check the mirror actuators?
Old Apr 3, 2020 | 02:08 AM
I re-read your original post. Go into the MID and turn off the memory seat check in the settings. Details on how to do that are in the manual but it's pretty self explanatory.
tman
4G TL Problems & Fixes
Oct 9, 2010 11:54 PM
millsjq
Sep 4, 2009 11:51 AM
bukjoe15
Mar 21, 2009 12:59 AM
cwcw
Feb 5, 2008 11:08 AM
diori
Dec 15, 2004 04:51 PM
