Screeching noise at low rpms
Hey, i been trying to figure out a screeching noise that only comes on when i press the gas and the rpm is around 2000..The car (2005 TL 3.2 AT w/Nav approx 105kmiles) has been checked multiple times, to include the catalytic converter and the flex pipe but everything has checked out fine. Is there something they've missed at the dealer?? Has anyone had this problem?
Could be the timing belt. There's a TSB for a shim kit to be installed.
has the OP had the timing belt done yet? 105-120K is when your drive belts will be at the end of their useful life and need to be changed. T-belt is technically due at 105K so ff you hae not changed it, get it done
Remove the serpentine belt and see if the noise is still there.
Do you gave a cai, does it make a difference from hot to cold?
joflewbyu2
10-08-2015 11:16 AM
4drviper
09-23-2015 09:00 PM
STL TL-S
09-23-2015 08:52 PM
