Rough idle after battery disconnect
Old Aug 20, 2019 | 04:09 PM
donkiboy's Avatar
I've noticed that whenever my battery dies (long overdue for new battery) or when I disconnect battery cable the RPM would dip (feels like stalling) and surge back up to normal.
This seems to happen after a revving it up in neutral or when I take my foot off accelerator when coming to a stop.
Is there an engine idle relearning period that the ECU goes through?
Old Aug 21, 2019 | 10:58 AM
blueknigh7's Avatar
Replace the battery. You're killing your alternator at the same time, unless you're looking to replace that too. It's not designed to support all of the electrical on its own, or continually charge a dead batt.
The ECU does have an "engine cycle" for smog purposes. Not sure if it learns an idle, but I don't think so.
Cars used to die on the road when the battery was dead but the alternator was still good. My guess would be that everything almost stalls in your car until the alternator takes over. A nice safety implementation, but again - just replace the battery. PS - why would you disconnect the battery while running?
Old Aug 21, 2019 | 11:01 AM
if your battery keeps dying, you potentially have a parasitic draw, stop fixing the symptoms, and fix the root cause.
Old Aug 21, 2019 | 01:58 PM
donkiboy's Avatar
I don't disconnect while it's running (I disconnect battery each time to reset my clock, since my nav screen is broken). I meant to say whenever the battery cable is removed and reconnected, it exhibits rough idle.
After each revving up of engine and instead of going to idle, the RPM drops to 400-500 causing a shake / stalling sensation.
I was just assuming that car goes through relearning / cycle test, upon each resetting of ECU (battery disconnect).
Old Aug 21, 2019 | 02:25 PM
You can pull the clock fuse to also reset the clock as well.
It does do an ECU reset when you disconnect the battery
https://acurazine.com/forums/third-g...-happy-747662/
Old Aug 21, 2019 | 03:34 PM
Have you tried something like the procedure below?
Originally Posted by mrkingstonvi
Ok OP here's the procedure: (Skip Step 2 since your ECU is already reset or if you want to reset it again via the Pedal procedure then proceed.)
1. Make sure all electrical items (a/c, audio, lights, etc) are off.
2. Reset the ECM/PCM (pulling the power by unplugging the battery works well).
3. Turn the ignition switch ON (II), and wait 2 seconds.
4. Start the engine. Hold the engine speed at 3,000 rpm without load (in park or neutral) until the radiator fan comes on, or until the engine coolant temperature reaches 194 F (90 C).
5. Let the engine idle for about 5 minutes with the throttle closed. (NOTE: if the fan comes on, do not include its running time in the 5 minutes.
https://acurazine.com/forums/third-g...set-sm-948953/
Old Aug 21, 2019 | 09:47 PM
csmeance's Avatar
ECU looses idle once voltage goes below 12Vs. A bad battery during startup will go down to 8 or 9V so that's causing your idle issues...
neil0311
Oct 9, 2018 10:25 PM
jctzin
Aug 18, 2008 04:54 PM
NighthawkBlue
Jun 18, 2006 06:46 PM
TL_TypeS
May 3, 2006 03:46 PM
NYZGREATST
Nov 29, 2004 12:10 AM
