Rough downshift while decelerating
Old Jun 16, 2011 | 12:25 PM
dabomb4ever's Avatar
3rd Gear
I have a 2008 Acura TL A/T, and the downshift during decelerating has become more abrupt and harsh. The car has about 56K miles on it. Has anyone else experienced this issue? Would a simple transmission fluid change solve the issue or is this been known to be more solenoid related?
Thank you.
-Nick
Old Jun 16, 2011 | 02:33 PM
dwb993's Avatar
Search for "Grade Logic" and read up on this feature of our cars to see if it is normal.
Old Jun 16, 2011 | 07:39 PM
3rd Gear
Thank you for the reply, that pointed me to others who are experiencing the exact same phenomenon. It is a bucking feeling in the downshift (progressively worse than when it was new), and sometimes randomly I get the high rev downshift on the transmission when I am coasting. In both cases I am not on a slope, I am on the freeway completely flat. In fact it is almost as if the car believes I am on a slope.
Searching through the previous threads, it appears there is no clear solution. Some suggest ATF flush, most say it is just normal. Has anyone found a remedy for this?
Thanks.
-Nick
Old Jun 16, 2011 | 09:07 PM
dwb993's Avatar
You could try replacing the pressure switches. Search for a thread started by user "ihatecars" titled "Interesting conversation". Its a rather long thread, but it explains all you need to know about the pressure switches, which are known to go bad. Check your fluid for a burnt smell and discoloration---it should be a reddish pink color. If it's brown and smelly, you need to replace. Most guys are going with a full synthetic fluid. I use Redline D4, although the Type F Racing fluid is most recommended.
Mike Pilipenko
Mar 26, 2024 09:21 PM
baelim
May 10, 2018 09:53 AM
DerrickW
Nov 15, 2015 05:52 PM
ceb
ILX
Sep 27, 2015 10:56 AM
