Replacing TL axles
Old Feb 10, 2013 | 12:24 AM
oh-yaa's Avatar
Replacing TL axles
I have an 05 TL auto. The axles are making the dreaded ticking noises on turns, especially when it is cold.
I've searched about replacing the axles myself here. I will probably get OEM parts since the originals have last for 150,000 miles. My question is how should it take to replace an axle? Is one side more difficult than the other? An special tips or tricks to make the job easier? It doesn't seem to require any special Acura only tools.
Old Feb 10, 2013 | 09:21 AM
mille_3's Avatar
Not very difficult. Be careful to not damage your ball joint when you separate the spindle. After that yank out the old half shaft and push in the new one. Make sure the half shaft is seated properly. Be prepared for a bit of oil spillage.
Old Feb 10, 2013 | 12:16 PM
oh-yaa's Avatar
Does the alignment need to be checked afterwards?
I should be able to complete the axle swap on both sides in about 6 hours? The axle nut seems to be the biggest problem due to it being so difficult to break loose.
Old Feb 10, 2013 | 12:52 PM
GKinColo08TL's Avatar
Anytime you do driveline/suspension disassembly/assembly you will need an alignment.
Old Feb 10, 2013 | 01:59 PM
Turbonut's Avatar
No, you won't need and alignment as the only adjustment is toe and changing an axle won't change that setting.
Make certain that on the right side, passenger side, you remove the axle from the intermediate shaft, NOT from the trans.
Feb 25, 2020 09:57 AM
jblessing
Aug 8, 2018 09:43 PM
marcelft
Jul 10, 2018 06:17 PM
justin7779
Dec 25, 2015 10:33 PM
jblessing
Wash & Wax
Sep 17, 2015 09:28 PM
