Replacing O2 Sensors
what year is your TL
Who said it needs BOTH sensors and WHY
The O2 sensor may be warranty item for an extended mileage
94 DC4 RS LSV/Turbo
you will most likely have to remove both primary cats, it is very tight in there
remove passenger side fan
strut bar
jpipe
axle shield
and some plastic guards underneath
strut bar
jpipe
axle shield
oxygen sensors
It has 58900 on it 04 TL
Could it be I pulled the LAF fuse?
I was looking for something else, light came on afterwards. Would pulling the fuse throw a code? I will reset tomorrow and see if that fixes it.
I got the rearview / power mirrors etc. back with the fuse switch - I am very happy with this forum...
Grimace-
and the dealer said not covered under warranty?- did you call acura and ask- plus bypass the service writer and go to the service MANAGER
acura-care 1-800-382-2238x5
even if not covered sometimes those conversations wil get you ~goodwill~ repair
Use of cheap Non Tier 1 gas will cause many problems.
Fixed - Fuse issue
I found the cause - the fuse was out marked LAF -
I was really mad at the dealer for not finding this and wanting to charge me @ 700!!!
Ann Arbor Acura #$^$%$
mada51589
05-03-2022 08:54 PM
cycdaniel
12-17-2019 10:58 AM
