Which Replacement Battery?
Spinnin them beats
this morning for no apparent reason, the battery in the TL is DEAD.
ive read these problems about the battery sucking so probably just going t go and buy one from autozone rather than the dealer just because of how far it is.
people all say optima yellow top - why? it has 200 less cold/reg. cranking amps than some duralasts and the duralast is 100$ cheaper... are you just buying the name or is it really that reliable when even the crank amps are lower?...
Gold-Duralast / Battery
Warranty - 8 YR 24F-DLG
Price: $84.99 Core: $12.00 Total: $96.99
Note:
*** 750 cold cranking Amps (935 cranking Amps) *** -> 3 year free replacement <-
Optima Battery / Battery
Warranty - 2 YR D35
Price: $209.99 Core: $8.00 Total: $217.99
Note:
*** 650 cold cranking Amps (810 cranking Amps) *** May require bottom height adapter, check hood clearance. -> 1 Year free replacement <-
Note:
Warranty - 2 YR D35
Note:
A lot of the original '04 batteries have been hitting that 'age'. I replaced mine a few months ago when it tested at about half the cranking capacity.
The yellow EverStart Maxx from Walmart is highly rated in Consumer Reports, about $70 with trade-in. It's the one I went with. So far, so good.
UMM YEAHHH, you def. need a new one, and I would run new Power wire, so that you get rid of all the corrosion otherwise its a never ending thing, even if you pour coke to neutralize the corrosion
I just bought a 05 Tl TONIGHT!!! I bring it home and the battery seems to have died. At first the starter wouldn't even try and after about twenty minutes it started the rapid clicking! I'm so pissed. It has 38,000 miles. Help!
You need a new cable.
Clean the corrosion with a baking soda and water solution, and keep it clean and greased from now on and it won't break again.
I picked up an EverStart battery from Walmart last fall based on the reviews in Consumer Reports and elsewhere. 875 CA / 700 CCA, fits perfectly, and is dirt cheap (think it was around $50-60).
Originally Posted by 6spMike
You might not need a battery.
I got a question that is pertaining to this topic... how come the TL dies so quickly when you have the music (stock audio system) thumping for about 15 mts with the car off or sometimes even during the duration of filling up gas at a gas station? Would replacing the battery give me more run time and less need to worry about that I need to shut all the electronics off everytime I'm idling?
mada51589
05-03-2022 08:54 PM
cycdaniel
12-17-2019 10:58 AM
BlkTxAcuraTypeS
10-18-2015 08:05 PM
