Oil pan drain bolt was stripped by mechanic a couple of years ago. My workarounds are done and I need to replace the pan. Reviewed the FSM's and several YT vids. The vids show it's not necessary to remove the A-Pipe, but rather that you can disconnect it and swing it out of the way. Cool.
So I get under the car today and start removing the nuts and bracket holding the A-Pipe in place. I'm in Arizona so no rust, but those nuts were a b*tch to crack.
But here's the problem: even with the nuts & the two hanging bracket bolts removed, the very front of the A-Pipe isn't clearing the subframe. I need about a half-inch more clearance to separate that section from the bolts that the nuts were holding it in place.
I'm sure there's a simple and stupid way of doing this. I don't want to lower the subframe again, so where should I try to jack up the engine or tranny to create the clearance I need?
Any suggestions welcome!
