Removed Emblems, imprint in clearcoat?
Old Oct 10, 2010 | 07:32 PM
autbond's Avatar
6th Gear
I removed my Acura and TL emblems off of the trunk lid and removed all the glue and there was an imprint still left behind (can see acura and TL in the trunk still). I took it to a detailing shop and they tried wet sanding it twice and buffing it about 5 times on each and you can still clearly see it if your standing in the right light. Any ideas on what to do here? I might just get it repainted and the A removed also, but this is a last resort. Anyone know where to get some black emblems to put back on? Thanks ahead of time!
Old Oct 10, 2010 | 08:59 PM
guitarplayer16's Avatar
http://www.heeltoeauto.com/Heeltoe-B...-pr-65613.html
Old Oct 11, 2010 | 01:58 PM
autbond's Avatar
6th Gear
Thanks for the reply, but those are really expensive. I can get the trunk lid painted for that. They do look good, but not $189 good. THanks again though.
Old Oct 11, 2010 | 06:54 PM
cipdagr3at's Avatar
HASTA LA VICTORIA'
Can you just paint it yourself, or do you where you can get some red ones...
Old Oct 11, 2010 | 08:00 PM
Yup, you can paint your original emblems yourself.
cjTL did so, I believe.
Old Oct 11, 2010 | 09:55 PM
hophamson's Avatar
To get the imprint off...what I did was clay the hell out of that spot. I didn't push it hard, but just claying it over and over at that imprint spot.
Old Oct 11, 2010 | 09:58 PM
AMUA6's Avatar
ScoobyZINE
I say paint the emblems if you don't want to shell out the loot to have the whole trunk repainted
Old Oct 11, 2010 | 10:17 PM
Bearcat94's Avatar
AZ Community Team
He had a detailer wet sand the area. Twice.
I'm not sure clay is going to help this time.
Old Oct 12, 2010 | 01:08 AM
djmanu's Avatar
i used some plastx and some scratchx with a small buffer adapter to my drill to get the imprint out. easy and quick.
Old Oct 12, 2010 | 01:12 AM
finalcross's Avatar
That sucks. I just rubbed some Goo-Gone on mine and it came out clean.
Old Oct 12, 2010 | 08:28 AM
dwb993's Avatar
It sounds like your trunk may have been clear coated at some point and the shop didn't bother to remove the emblems before spraying. Not the first time this has been reported on AZ.
If the wetsand did not remove it, then you will need a respray. Or you can get a can of paint and DIY your emblems and replace them.
There was a thread a while back about using VHT Nightshades to get a black chrome look, but I couldn't make it work. Im waiting on a set of Marcus' emblems now.
Old Oct 22, 2010 | 03:15 AM
stp2585's Avatar
i had the same problem that you have. Took off the emblems, and there was a shadow of the emblem visible. I went to a car wash and asked them to use some wax and a buffer to take it off. They used "miracle wax" and a buffer and it came right off. Can't see it anymore at all at any angle.
Hope this helps!
iRaw
ILX Photograph Gallery
30
Aug 5, 2016 04:41 PM
LogicWavelength
3G TL Photograph Gallery
33
Nov 1, 2015 09:38 AM
dainmezron
Oct 16, 2015 06:56 PM
lowgrowl
Sep 26, 2015 05:18 PM
Dman00tl
2G TL Photograph Gallery
Sep 25, 2015 10:34 AM
