REDLINE ATF Transmission fluid
Hello guys,
Can somebody tell me which REdline ATF is the best to use after 100k miles? My car just hit 100k and i did an ATF change on 60 k by a dealer. I did a lot of research and most of acura owners stating that acura atf fluid is not a good choice. So I'm just curios which redline atf should i use for smooth shifting. I read that s`ome people mixing the fluids for a smoother shifting. What you would recommend?
BANNED
Honda ATF gives the smoothest shifts at first, but the most clutch wear which leads to poor shifts. With Redline the shift is not as smooth, but clutch packs will last a lot longer and shifts will not degrade as much.
BANNED
SidhuSaaB
05-30-2020 12:40 AM
