Rear View Mirror stuck on dim
Did a search but did not find exactly what I was looking for. My Rear view is stuck in auto dimming. I tried turning it off but it still the same thing. In some threads with the rear view mirror problem most have suggested a replacement but the dealer will rape you especially if the car is out of warranty and with a slight chance that they might goodwill it ( I have 58K on my 06). Does anyone have a step by step replacement procedure with pictures? I mean is it a 15 minute job?
2016 Acura TLX
I've got the same issue and the little green light no longer lights.
2016 Acura TLX
Bump?
2016 Acura TLX
nvm, i think i found my issue
TSB 05-033: Power Mirrors, Auto Dimming Mirror, Power Seat Position Memory, and Windshield Washer Do Not Work (Revised 10/14/2005)
describes exactly the things that don't work
2016 Acura TLX
It's actually an auto dimming mirror, meaning that it's either off or auto. During the day, the mirror should go back to normal even in auto mode. Only way to keep it on all the time is to put tape over then sensor.
Jokerman
Thats what I meant, i leave it in auto all the time. But if you put tape over the sensor then it will never dim thinking that there is no lights behind you, the sensor detects the amount of light and adjusts the amount of dimming.
2016 Acura TLX
mine had an issue where it was dim the whole time. it wouldn't adjust back to normal.
BoricuaTL
04-08-2016 01:08 PM
dre707
09-08-2015 08:32 PM
