Rear Motor Mount-Beck/Arnley 104-2127
Anyone have experience using a Amazon $98.00 Beck/Arnley 104-2127 Rear Motor Mount 2007 Acura Type S Auto. The reason is I found one new for way less than retail. Are Beck Arnley made in Japan?
Thanks,
Thanks,
But it now-$47.15 ($30+$17.15 shpg)
https://www.ebay.com/p/Engine-Mount-...L-V6/214914933
In this situation, I say a mount is a mount so save money, but if you're like some others that feel Honda/Acura parts are the best that can be had, then spend the extra money purchase OEM $159/$116.
I checked the ebay link $100+. I swear yesterday it was @ $50 including shipping.
I'll try again $30 + $17.15 shpg.
Engine Motor Mount Rear Beck/Arnley 104-2127 fits 04-08 Acura TL 3.2L-V6 eBay
I'm not sure on what aftermarket parts are the same as OEM, but especially for this car, I would stick to OEM mounts. Two main factors for that are the OEM engine mounts are liquid filled, which help in their dampening capabilities. The other reason is the front and rear mounts are vacuum controlled on the 5AT's. If you lose the vacuum controlled mounts, you will have significantly increased vibrations in the cabin. I had one of my vacuum lines not attached on the front mount and had a lot of vibrations before figuring out the dealer neglected to hook the line back up. Maybe the vibrations won't bother you that much, but I have read other issues on the forums with increased vibrations while accelerating as well. I am not sure I have read anything positive about any non-OEM mounts, so just keep that in mind while purchasing.
ExcelerateRep (06-06-2017)
horseshoez (06-06-2017)
