Rear E-brake Pic needed
Old May 20, 2011 | 10:10 PM
stickercutting's Avatar
Does anyone have an image of their rear e-brake setup assembled and ready for the rotor to be put on?
I did my rotors today and tried to get the rotors off. The adjustment screw wouldn't turn so we had to literally beat them off the car. In the end, we sheered both tension pins and bent the bottom longer spring.
I'm not much of a diagram person, so I need an actual image of how the springs, etc. look before the rotor goes on.
Can anyone help? Really would appreciate it. This is my first time doing rear brakes, rotors, etc. and it didn't go exactly as planned
Old May 20, 2011 | 10:16 PM
I've searched this forum a million times, searched google as much, still just can't find one to show how they go together.
The diagrams just don't show enough to make sense of it.
Old May 21, 2011 | 12:04 AM
paperboy42190's Avatar
this is the exact reason why people do brakes one side at a time, so that there is always the other side to look at if you dont know how it goes together.
Old May 21, 2011 | 12:12 AM
I have the other side to look at, but the jack is only on one side...so I figured a pic would be great to fix one side, then check the other side...
Both sides aren't screwed up as far as I know...only the passenger side, which had an insanely tight rotor...
Old May 21, 2011 | 07:07 AM
vill0169's Avatar
AZ Track Whore
I'd tried to tell someone else a while back that the adjustment screw on the drum brake is definitely something to look at while doing the rear brakes. this just proves my thought was valid.
So how hard did you try to move the adjustment screw? tried it both ways too?
Look in the TL Diet Thread, he might have a pic in there of it. I'll be a nice guy and look as well.
Old May 21, 2011 | 07:14 AM
vill0169's Avatar
AZ Track Whore
Let's try this.... It's not great but it's all Inaccurate had in his thread.
Old May 21, 2011 | 03:19 PM
nfnsquared's Avatar
Originally Posted by stickercutting
Does anyone have an image of their rear e-brake setup assembled and ready for the rotor to be put on?...
https://acurazine.com/forums/3g-tl-2004-2008-93/d-094-diy-complete-brake-job-pics-624404/
Scroll down to Step 5.
I know you said you're not a diagram guy, but here they are just in case:
Old May 22, 2011 | 02:06 PM
Thanks so much - such a life saver!
Yes, definitely use the adjustment screw that is at the BOTTOM of the assembly (going through the access hole on the rotor), get to it with a screw driver. A lot of people don't mention it's importance and they more or less mention "just beat it off the hub", but you will cause more damage then you would like.
The first thing that broke was the tension pins on the left and right hooked to the silver brackets. The spring at the bottom also got tweaked during the beatdown. All in all it was only about $7 worth of parts (plus new pads), but still, it's annoying to have to deal with. Definitely a lesson learned...even after all the reading I did to make sure I was doing it right, I missed one step and caused a headache for myself.
Thanks for the help, the pic is just awesome. If anyone has a higher resolution one, that would be cool too.
Old May 22, 2011 | 02:48 PM
just making sure. you DID loosen the ebrake when trying to take off the rotor right? thats a common mistake why the rotor stays on so tight...
Old May 22, 2011 | 03:29 PM
Yes I definitely did that...wasn't THAT dumb, haha!
I'm not sure why it was so stuck, with so little adjustment...very weird.
Old May 22, 2011 | 03:35 PM
Does anyone have any tips on how to get these brakes back into spec? I understand the "turn the spike wheel until it touches the rotors and then turn it back 6 times" - is there anything else I should know that the instructions don't already spell out?
Old May 22, 2011 | 03:36 PM
Turn it until the pads touch the rotor, that is...can't edit things...
Old May 23, 2011 | 01:49 AM
Inaccurate's Avatar
Below are close-up pics. Please be aware that my pics might inaccurately (bad pun ) represent how they should be assembled.
I had to disassemble them to remove them for my TL Diet. I just quickly threw them back together (haphazardly) after having remove the assemblies. I knew that I would not ever be reinstalling them, should I did not take care in piecing them back together.
Old May 24, 2011 | 02:02 AM
cokinut's Avatar
i
I just got done doing mine as well. One side at a time. I bought stupid pep boy pads and they were took freaking big. Bought the OEM pads + all hardware for $150 and everything worked like a charm.
Don't forget to lube the points mentioned in the manual. You will want a little friction when it's installed. It should be able to do about 1 rotation before coming to a stop because of the friction.
Old May 24, 2011 | 07:18 AM
nfnsquared's Avatar
Yeah, follow the manual instructions I posted and do the lining brake-in procedures. After all that is done, you may need to make major/minor p-brake cable adjustments. These procedures are posted in the forum. Do a search to find them.
mada51589
Jan 9, 2025 04:40 PM
Feb 25, 2020 09:57 AM
TLDude876
Dec 28, 2016 03:18 PM
wilztlxs
Dec 1, 2015 09:16 AM
nanos
Nov 12, 2015 08:41 PM
