Really need help Code P0420 & Limp/Home mode
Old May 9, 2013 | 11:19 PM
a3scobar's Avatar
Helllo everyone, im so frustated with this i need your help i will really appreciated,
I have an old 04 TL and has the check engine light one, i check with Autozone and they told me is code P0420 o2 sensor, and now my car goes out to limp home mode (2nd & 3rd shit 2.5k revs)
If erase code the car goes good a few days and then happends again.
What should i do?
recent repairs
Change sparks
Cleaned Throttle (Reprogram)
Change pcv valve
Please help is my every day ride and really neld to solve this asap
Old May 10, 2013 | 02:05 PM
carz0159's Avatar
double check the code, I'm pretty sure the car should not be in limp mode for an O2 sensor. I drove for years without one in my other car.
Old May 10, 2013 | 02:06 PM
well, if the code is for the 02 sensor....change the 02 sensor....
also, the catalytic converter could have gone bad
Old May 10, 2013 | 02:22 PM
nfnsquared's Avatar
What should i do?
recent repairs
Change sparks
Change pcv valve
Cleaned Throttle (Reprogram)?? Huh?
Old May 10, 2013 | 02:41 PM
a3scobar's Avatar
I was told by my mechanic that it the limp mode was caused by a thorttle fault and told me i need to replace it, but since theres no other code than P0420 i took it today to a speaciallist cheked my cat and been told that cat #2 the one from firewall need to be replaced but still my mechanic say that that is not the cause of my limp mode...
Old May 10, 2013 | 02:57 PM
nfnsquared's Avatar
I'm confused... So the code happened first and you took it to your genius mechanic who did those 3 things and it didn't fix it?
Old May 10, 2013 | 11:40 PM
carz0159's Avatar
well, limp mode is definatly not caused by the o2 sensor, it theres a fault in the throttle, i guess it has to do with the app sensor, and you should give that a go.
go to an acura or honda dealer so that they can diagnose it, ik its more expensive, but its easier and better and sometimes cheaper than having an inexperienced mechanic deal with it
Jamus22
Jun 11, 2023 10:08 AM
MilanoRedDashR
Oct 2, 2015 10:49 AM
hashbrown
Sep 29, 2015 12:13 PM
thegipper
Sep 28, 2015 01:01 PM
shawnafoxx
1G RL (1996-2004)
Sep 28, 2015 12:33 PM
