Problem with power windows
Old Jan 1, 2011 | 07:09 PM
josiel's Avatar
hey everyone whats up HAPPY NEW YEAR!!
ok so my passenger side window when im going to close it if i press the button all the way up so it does the auto close it goes back down when its like 3/4 of the way up, but if i just press the button to the first click and close it leaving the button pressed it will close
Old Jan 1, 2011 | 08:57 PM
cjTL's Avatar
I'm Craig
My driver's window sometimes does this. I think it's seated wrong just barely in the window track because it still closes and seals properly when I do it manually. The window stops going up because it thinks something is in the way. As for the solution: silicone lube makes it work for about a month or two. Just spray it in the side parts of the track where the window stops going up on its own, etc.
Old Jan 2, 2011 | 03:44 PM
josiel's Avatar
I'll try that and see thanks
Old Mar 3, 2011 | 12:18 PM
hex8586's Avatar
Hey guys my passenger window is a little weird. I can put the window up and down with no problem if I do it manually but, if i use the auto, it goes down but wont go up. I have to pull the window up with the button and my hand.
mazen222
Oct 27, 2015 12:01 AM
k6biv
Sep 10, 2015 06:37 PM
ahsm
Sep 9, 2015 08:35 AM
sputik
Sep 7, 2015 01:40 PM
