Problem with Homelink
I have tried to set-up the Homelink and it does not work! Anyone else having a problem with this?
I did everything the instructions said to do - over and over, and still - it will not work!!
![Annoyed](https://acurazine.com/forums/images/smilies/annoyed.gif)
Registered but harmless
Received 1,106 Likes
Need more description as to what you are doing and the remote you are trying to link.
Try clearing the Homelink completely per TL owner's manual directions, then going into setup. If that doesn't work, you may have a rolling-code remote which involves accessing the [garage door] receiver's "learning" mode per owner's manual.
The DVD-A Script Guy
Whay kind of opener?
FYI - My openers are Genie's from around '97 with rolling codes and they work fine.
Unshunned
I did everything the instructions said to do - over and over, and still - it will not work!!![Annoyed](https://acurazine.com/forums/images/smilies/annoyed.gif)
The TSB states that you need a GENIE brand remote to program the homelink. If it doesn't work from that, then you must have the homelink unit replaced.
Call your dealer and mention that, see if they have a genie remote you could try it with.
05 TL
I had mine replaced.... The dealer was telling me that my VIN wasnt in the recall... Told them that it still didnt work... I got a new one, and it works just fine.
With rolling codes there's a button on the garage door receiver. You push that button, and then do the homelink thing on the car.
Oderint dum metuant.
All of Overhead Door's openers have rolling code. As was previously mentioned, you will need to push the button on the opener, then follow the steps to program the car. There's a second set of instructions in the manual for how to set up Homelink with rolling code openers. You either need two people or have to move rather quickly (down the ladder, to the car, push the button, etc.)
Originally Posted by chill_dog
All of Overhead Door's openers have rolling code. As was previously mentioned, you will need to push the button on the opener, then follow the steps to program the car. There's a second set of instructions in the manual for how to set up Homelink with rolling code openers. You either need two people or have to move rather quickly (down the ladder, to the car, push the button, etc.) ![Big Grin](https://acurazine.com/forums/images/smilies/biggrin.gif)
Thanks! I appreciate everyone's help! I will try it again!
RIP Dime...
Try doing a search as well for the garage door openers. Try this https://acurazine.com/forums/showthread.php?t=106070
![Roll Eyes](https://acurazine.com/forums/images/smilies/rolleyes.gif)
Go to www.homelink.com. The web address is in your manual. I found the directions much better online than in the manual.
Good Luck!
Good Luck!
lol, didnt read the previous posts, but you must program your garage door opener to your home link first (if its the rolling code), then do the button on the door motor next using the same homelink button.
Keep Right Except to Pass
The instructions in the owners manual imply that for rolling code system you follow the 2nd set of steps. In fact you do the entire set - single code followed by rolling code.
I initialy had problems in my 2002 TL, and again in my 2006 TL. I have a Genie opener. Turned out the solution was really simple. I was trying to learn the main button on the remote (the one that opens the door). For some reason this refused to work. I tried training the homelink with one of the other unused buttons on the genie remote, and it worked great. Of course I didn't remember this a few years later when I bought the 06, and wasted about 2 hours in my driveway trying to get it working.
Hope this helps,
Dave
Hope this helps,
Dave
Mike's Silver Bullet
BammyZ,
Do a search on this topic if it still doesn't work. Someone else had an opener with rolling codes, but a different frequency or something. I forgot exactly what the resolution was.
Programming Homelink
Hey guys, I was reading through these posts and I noticed there seemed to be some confusion regarding programming the homelink to a rolling code garage door opener. To properly program them it will help to understand how they work.
With the rolling code system, you must first use a transmitter to train the homelink what to transmit. Upon completion of this, you must go to the "learn" or "teach" button on the garage door opener, press it, then go back to your newly trained homelink button and press it several times so that it will be accepted by the garage door opener.
To say it another way, training homelink for a rolling code system involves 2 steps. First train homelink with a transmitter, then pair up homelink with the garage door opener by pressing the "learn" or "teach" button and then (within 30 seconds) pressing the homelink button.
As some have said in this forum, it is a good idea to clear the homelink system before starting (press and hold buttons 1 and 3 for about 20 seconds). Check out the homelink site for interpreting the blinking homelink light and what it is telling you. Good Luck
SidhuSaaB
05-30-2020 12:40 AM
