Power Steering Rack & Valve Cover Gaskets Replacement
Old Nov 1, 2021 | 01:23 PM
LoveMy2006TL's Avatar
4th Gear
On 10/15/21, a Service Advisor at an Acura dealership told me that my power steering fluid was low and that the power steering rack was leaking from both sides, and recommended replacement. They also stated that the front and rear valve cover gaskets were leaking. After reviewing my service records, I discovered that I had both the power steering rack as well as the valve cover gaskets replaced on 5/27/18. How is it possible that I would need to have both the power steering rack as well as the valve cover gaskets replaced 3 ½ years later? That seems like an awfully short period of time, especially considering it was 12 years before I needed to replace them the first time. Any thoughts on how long those repairs should generally last? Thanks
Old Nov 1, 2021 | 02:15 PM
peter6's Avatar
Monitor the power steering fluid. In many cases rack is slightly wet but fluid level remains about the same for years. Maybe one of the hoses is leaking?
Hard to tell about valve cover gaskets. I've done mine recently because I was taking a look at the valves, and original gaskets weren't leaking despite having 120k / 13 years on them.
If somebody used cheap parts chances are that everything that acura dealer told you it's true, but from my experience dealers tend to be very picky about their inspections.
Meaning if something is not brand new and shiny they will recommend replacement.
Old Nov 1, 2021 | 02:26 PM
4th Gear
Thanks - the dealership originally replaced the gaskets and power steering rack so I’m sure they used genuine parts. I just can’t believe they think they need to be replaced so soon. I think I’ll take your advise and just monitor it for a while. I also sent my concern to the dealership service manager and awaiting his response. Thanks again for your input.
LoveMy2006TL
Oct 30, 2021 03:20 PM
dirtyspitshine
Jul 27, 2020 07:40 AM
Knig95
Feb 5, 2017 11:11 AM
ShagJagJim
Aug 4, 2015 11:59 AM
prarce2
Nov 6, 2013 06:44 AM
