please help acuraziners!!!!!!!!!!!!
where is the fuse box and what fuses are for the foglights on a 2007 acura TL base. i put new brighter foglights on previously jus getting factory fogs the week before after putting new fogs in they dont work i put the old ones back in they still dont work all i can think is fuses..............please help.
^^^^ x2.
Do you not have an owner's manual? Read pp 245-247 (or around there).
If you don't have an owner's manual, let me know and I'll help you out.
If you are still having problems read this thread, he had the same problem and fixed it.
https://acurazine.com/forums/showthr...t=fuse+diagram
http://techinfo.honda.com/rjanisis/p...404O00242B.pdf
Scroll down to pp. 245-247/
Why don't you have an owner's manual? Register at myacura.com and then you'll have access to an online owner's manual.
AZ Community Team
Received 7,771 Likes
There's a fuse and bus box under the hood; a fuse box near the driver's door under the dash. Don't remember if there's one by the passenger door or not.
Who's got links to Owners Manuals????
Edit: and there ya go.
i checked the bulbs already. i put the brand new factory bulbs in and it still doesnt work. the problem happen when i installed aftermarket bulbs=didnt work. Prior to me doing this the factory worked fine. I put the factory fog lights back in after the new aftermarket ones didnt work. Then they didnt turn on. Changed fuse nothing happens. so im stuck. any help?
Did you also check the fuses under the dash, left side footwell? Take the little door off and it will tell what fuse is for what. Find the fog light fuse and check it. If blown, replace.
The only fuse (at least in the 04TL) that I can find for the fogs is #10 in the under hood fuse box. I don't see one for the fogs in the under dash fuse box.
OP-be sure you don't have your brights on. The fogs won't come on if the brights are on.....
mugen_kid
11-13-2015 10:38 PM
oyayjoe
09-12-2015 04:40 PM
