please help acuraziners!!!!!!!!!!!!
Old Sep 27, 2010 | 05:21 PM
kasualballn's Avatar
where is the fuse box and what fuses are for the foglights on a 2007 acura TL base. i put new brighter foglights on previously jus getting factory fogs the week before after putting new fogs in they dont work i put the old ones back in they still dont work all i can think is fuses..............please help.
Old Sep 27, 2010 | 05:25 PM
AMUA6's Avatar
ScoobyZINE
Seriously, bro?
Old Sep 27, 2010 | 05:27 PM
nfnsquared's Avatar
^^^^ x2.
Do you not have an owner's manual? Read pp 245-247 (or around there).
If you don't have an owner's manual, let me know and I'll help you out.
Old Sep 27, 2010 | 05:47 PM
Steve 21's Avatar
If you are still having problems read this thread, he had the same problem and fixed it.
https://acurazine.com/forums/showthr...t=fuse+diagram
Old Sep 27, 2010 | 05:48 PM
nope
^^^^ x2.
no owners manuall would appreciate the help im new on here sorry about the stupid question lol
Old Sep 27, 2010 | 05:49 PM
Disbe's Avatar
Unable to determine where the sentence started and stopped I became confused and gave up.
But yea, owners manual ftw!
Old Sep 27, 2010 | 06:01 PM
nfnsquared's Avatar
Fuse # 10 in the under hood fuse box. Here's a link to the 04 owner's manual page with a drawing of the fuse box location:
http://techinfo.honda.com/rjanisis/p...404O00242B.pdf
Scroll down to pp. 245-247/
Why don't you have an owner's manual? Register at myacura.com and then you'll have access to an online owner's manual.
Old Sep 27, 2010 | 06:04 PM
Bearcat94's Avatar
AZ Community Team
There's a fuse and bus box under the hood; a fuse box near the driver's door under the dash. Don't remember if there's one by the passenger door or not.
Who's got links to Owners Manuals????
Edit: and there ya go.
Old Sep 27, 2010 | 06:32 PM
o well tried replacing fuse for fogs still dont work.......................any other ideas?
Old Sep 27, 2010 | 07:10 PM
05TLdcc's Avatar
Coal
Have you looked to see if your bulbs are out? I think your over reacting a little bit. calm down and go look through everything you can think of. this is not that urgent of an issue.
Old Sep 28, 2010 | 03:30 AM
PowerCommander's Avatar
check wire continuity likely not the issue but good to check, making sure it's not grounding out. Then check, check, check polarity.
Old Sep 28, 2010 | 08:32 AM
Disbe's Avatar
If this guy is asking where the fuse box is located something tells me he has no idea what you mean by continuity and polarity. Wikipedia ftw! lol
Old Sep 28, 2010 | 03:13 PM
i checked the bulbs already. i put the brand new factory bulbs in and it still doesnt work. the problem happen when i installed aftermarket bulbs=didnt work. Prior to me doing this the factory worked fine. I put the factory fog lights back in after the new aftermarket ones didnt work. Then they didnt turn on. Changed fuse nothing happens. so im stuck. any help?
Old Sep 28, 2010 | 03:50 PM
LoveMyTL-S's Avatar
Did you also check the fuses under the dash, left side footwell? Take the little door off and it will tell what fuse is for what. Find the fog light fuse and check it. If blown, replace.
Old Sep 28, 2010 | 06:06 PM
nfnsquared's Avatar
The only fuse (at least in the 04TL) that I can find for the fogs is #10 in the under hood fuse box. I don't see one for the fogs in the under dash fuse box.
OP-be sure you don't have your brights on. The fogs won't come on if the brights are on.....
oyayjoe
Jan 1, 2019 10:17 PM
giovane
2G RDX DIY & FAQ
Jul 8, 2016 10:46 PM
mugen_kid
Nov 13, 2015 10:38 PM
GhostTL09
Sep 19, 2015 01:57 PM
oyayjoe
Sep 12, 2015 04:40 PM
