Piece on passenger door handle nearly came off
That piece apparently falls off quite often. Junkyard is always a good place to start, but if it's #33 on this diagram, it's about $11. I'm 95% sure that it's #33 on this.
I went based on a 2008 Base TL, you might want to double check with your year if it isn't '08.
http://www.oemacuraparts.com/auto-parts/2008/acura/tl/base-navigation-trim/5-speed-automatic-engine/body-air-conditioning-cat/front-door-locks-outer-handle-scat
uvb4less (05-17-2016)
The new one includes the metal piece that is left behind still on your door. You will want to gently detach the two parts of the new piece. Then the new plastic cover can be snapped right onto your old metal bracket. It's much much much easier than trying to remove & install that metal bracket from inside your door.
Registered but harmless
Received 1,150 Likes
FWIW, all of my door handle caps, except the one on the driver's door, have been changed.
Scottod102
03-08-2016 10:14 AM
Kesler123
2G TSX Problems & Fixes
02-26-2016 12:30 PM
