Passenger side window malfunction
This is the first time I've ever had a trouble with the above problem.
I lowered the passenger side window to say good bye to someone. When I tried to raise the window back up, I realized that it won't come up above 2" from the door frame. It took me about 30 tries to raise the window all the way up. I made a mistake of lowering it again to make sure that it was just a freak incident only to find out that it took more than 50 tries to raise it back up again. Has anyone else had this problem?
GOLDEN NUGGET
I had a similar problem about a month ago. The pass. window had frost on it and I had to put it down to see on coming traffic as I was making a left turn. When I went to put the window up, it kept on going down on it's own. It took me about five times to get it back up, but it hasn't happened since. I thought it might have been the cold weather and the frost, but it seems that now it might be more then that based on your post also...I hope it's nothing serious.
In GUMP's case ... I bet it was the frost ...
Thank you all. I will try to clean the door area with compressed air. It was very odd when it happened. I was worried about parking the car somewhere with the window down!
Team Anthracite Member
Man, not really the club I wanted to join! The other day - Wed? bitter cold here and I was out and somewhat lost so I was pulling over asking for directions - same thing the passenger window would go auto-down no problem, but the auto-up would go up and inch or two and then go back down. I could get around it by lightly pushing on the button to go "manual" up....so what is the verdict here - really a failure somewhere or is something dirty that I can clean?
Most modern cars have the safety setup on the windows, if they think someones arm/hand/finger is in the way they back off.
Most will overide the safety gizmo if you push the button twice.
Maybe its in the owners manual?
Ice and cold will increase the effort to move the window, and trigger the gizmo.
I can not say I like most of the new safety gizmos car makers have to add, I am not fond of stability control, abs, the window gizmo's, tire pressure monitors, etc.
I like being in control, and its just lots more (expensive) things to go wrong on the car.
Brett
Brett
Shift_faster
I've had it happen on two separate occasions. I had the window regulator replaced under warranty by the dealer. Go to the dealer...and have them take care of it.
It did it again - and it makes a struggling sound when it goes up - like it is binding somewhere. I will have them fix it for sure. Any areas easily damaged by a repair that I should look for before I take it from them after fixed? Door panel must come completely off I am guessing?
P.S. I am not so sure what the sensitivity is of these windows, but I put my hand in there on both windows and I could not get the windows to reverse direction or even stop for that matter!
One on the right for me
i cant remember if the TL windows have the safety feature or not...i thought it was just the sunroof...do i have it backwards? or is it both.
Both front windows have the safety feature when the auto-up is used. Instead of taking a chance with your hand, roll up a newspaper and test it. If it doesn't stop, take it to the dealer.
good idea Ron - I will test them both. Wifey was not too keen on putting her hand in there
marcelft
07-10-2018 06:17 PM
sockr1
10-01-2015 01:31 AM
