Passenger Side Mirror Resets to Wrong Position
Old Jan 11, 2011 | 04:04 PM
bluenoise's Avatar
2004 SSM/EB/5AT/Navi/RSB
Question Passenger Side Mirror Resets to Wrong Position
The passenger side mirror on my TL resets to the wrong position when I choose my driver profile (different from my wife's profile). When I unlock the car with my fob and open the door, everything moves to my preferred positions, but the right side mirror is always too low. Every time, I have to use the control to manually raise it up. Every time I then store the new setting. But, it never returns to my set position.
My guess is that the position sensor inside the mirror "thinks" it's in the correct position, though it isn't. Has anyone seen this or does anyone know what to check or test to track this down?
Thanks in advance.
Old Jan 11, 2011 | 06:40 PM
csmeance's Avatar
does it make a grinding noise? The motor may be inside and causing the issue with it skipping.
Old Jan 11, 2011 | 06:59 PM
bluenoise's Avatar
Everything sounds normal. The only issue is the offset position.
Old Jan 12, 2011 | 12:27 AM
Will Y.'s Avatar
Registered but harmless
Originally Posted by bluenoise
The passenger side mirror on my TL resets to the wrong position when I choose my driver profile (different from my wife's profile)...
Just set the mirror to the desired position, reset the mirror memory with the DPMS, then unlink/relink the remote fob.
Old Jan 12, 2011 | 02:28 PM
bluenoise's Avatar
How do I reset the mirror memory with the DPMS?
Everything moves to the correct position. The mirror moves, too, but not to the stored position. I'm not sure this reset will correct this, or if it's a hardware issue with the position sensor, but I'll give it a try.
Old Jan 12, 2011 | 09:39 PM
Will Y.'s Avatar
Set the mirror to the desired position, then store the positions in memory using the memory (DPMS) buttons on the door.
Old Jan 12, 2011 | 09:41 PM
bluenoise's Avatar
Ah OK. I mentioned that is part of my process in the OP. I just didn't realize the official term for it.
rockyboy
Aug 4, 2024 10:35 AM
Oct 21, 2015 11:38 PM
sockr1
Oct 1, 2015 01:31 AM
acuraST
Sep 17, 2015 02:31 AM
hand123
Sep 10, 2015 09:27 AM
