P0741 Transmission Code 2005 Acura TL Automatic
Old Jan 24, 2020 | 03:22 AM
ThaiTL's Avatar
I bought my Acura TL knowing that this code was an issue and thought that the TCC solenoids were the issue. After replacing the top two solenoids and replacing the transmission filter and fluid I cleared the code and drove around. After driving for about half an hour I plugged in my scanner and found the P0741 code as pending and after driving some more it become a stored code. The engine light isn't on and the car drives fine. When I removed the screw for the transmission filter I found some plastic clogging up one of the fluid passage ways and cleaned it out.
Could it be a wiring issue? The other two solenoids? Plz help
Old Jan 24, 2020 | 03:33 AM
ThaiTL's Avatar
I forgot to add that I checked the ohms for the 4 different solenoids (2 on top and 2 below the starter) and they all came within spec, 12-25 ohms while mine were between 14.8-16 ohms. While replacing the transmission filter I removed plastic clogging the passage way in the screw.
Old Jan 28, 2020 | 06:13 PM
indcoltsfan32's Avatar
4th Gear
Did removing the plastic fix your issue?
Old Jan 28, 2020 | 10:37 PM
Ron A's Avatar
Administrator
The following is posted at the top of the New Member Introductions forum: Welcome! Please introduce yourselves here, BUT ASK FOR HELP IN THE TECHNICAL FORUMS
Since this is a topic/technical issue which will require replies and discussion, and not an introduction, this thread has been moved to the model specific forum.
Old Sep 9, 2020 | 11:49 AM
Acura_TL2012's Avatar
I’m having the same issue, did you fix your problem, please let me know, I have the same code p0741 2004 Acura TL 210k transmission fluid is dirty!
Old Sep 9, 2020 | 02:06 PM
ThaiTL's Avatar
After draining the fluids and changing the filters and reseting the car, it runs fine now with no code
Old Sep 9, 2020 | 02:10 PM
how many qts it took? Did you use Honda ATF DW1. Also did you replace any solenoid vale. Especially TCC Solenoid? transmission filter have to be oem. Thank you for the information
Uncle Swaggy
Jun 9, 2021 05:48 PM
deetreyy
Sep 23, 2019 08:56 AM
Melinda Baker
Sep 14, 2019 07:38 PM
astro
AcuraZine Articles
26
Sep 3, 2017 06:16 PM
KushTL
Jul 31, 2017 07:11 AM
