P0717
P0717
Had a problem this week with my 06 tl. Driving on the highway at about 75mph when all of a sudden a heard a loud roaring sound. My rpms went up all the way to red area when trying to accelerate and the car would not go any faster. Next thing I know my VSA light and check engine light come on. I was able to pull over and open the hood as there was smoke coming out. Towed the car back home and checked ATF fluid and there is barely any left. Hooked up scanner and got code p0717 which is a input/turbine speed sensor. Filled up tranny with fluid and the car drives fine but wanted to leave light on in case I have to bring to shop. Car shifts perfect. From diagram below, can anyone tell me which speed sensor it is that I have to replace and also if this would cause the leak? Any input would definitely help. Hopefully the tranny isn't going bad.
^ replace trans as it is toasted. oh and welcome to the club of "I have had my trans replaced already"
It may run fine for a while but trust me, it's done. when you ran it empty it toasted the clutch packs
lol..what is the deal with trannys going on these cars.. so you think tranny lost even though its driving fine now and its giving me that code for the sensor?
ANyone else on which sensor it is on pic or maybe any inputs on what could have caused the leaks based on experiences?
^absolutely, you cannot run them low on fluid
dtmoney1
05-21-2019 07:27 PM
mark1980
03-13-2010 07:30 PM
