'04 drain bolt size
Old Jul 7, 2012 | 06:46 AM
Bruce Banner's Avatar
'04 drain bolt size
Everything I read tells me I need a 17mm socket.
I had a cheapie torin jack and couldn't get the car on stands, but I could see the bolt and filter so I gave it a try. (unsafe I know)
I put a 17mm socket on it and it did not want to fit. My stupid socket set skips 18mm and goes to 19mm.
I put on the 19mm and there was way too much play.
Is it a 17mm or 18mm for the 04 6mt?
Won't try it again till I get a proper jack, but wanted to know if it's normally a 17mm on this car.
It didn't want to fit, so I'll be getting a 18mm just in case somehow it really is an 18mm
Old Jul 7, 2012 | 11:32 AM
andrewg's Avatar
Should be 17mm unless someone else has replaced the OEM plug with something else in an attempt to repair damaged threads. I have encountered some cheaper tools that are sized incorrectly and are too small to fit, and this may be your issue. I don’t think Acura/Honda uses 18mm for anything.
Old Jul 7, 2012 | 03:34 PM
I can see if maybe the socket is sized incorrectly. This socket set has been working for me so far, it's a stanely set. I even reached for a SAE socket and got the same result. would not slip on and too much play.
the "17mm" wasn't an issue of covering and spinning, the nut was not going in, I kept spinning it to get it to seat. Heck oddly enough , this set doesn't have a 18mm or sae similar.
I do kinda suspect somebody along the way replaced it with something else if the 17mm is not fitting.
Old Jul 7, 2012 | 08:45 PM
I'm pretty sure my socket is not the wrong size. I can see some oil wetness at the bolt. It starting to look like it was stripped and whomever along the way decided to thread it with a larger bolt. Pretty dam sure it's a 18mm bolt there now on my drain.
neuronbob
23
Jul 16, 2019 10:48 AM
ExcelerateRep
Oct 14, 2015 08:20 AM
hpfiend
Sep 27, 2015 06:59 AM
dirleton
Sep 25, 2015 12:25 AM
ROSSARONIE
Sep 22, 2015 11:46 AM
