P0430
Old Jun 16, 2014 | 01:44 PM
Joey tl's Avatar
04' tl 6 spd
P0430
Which sensor would I replace..... My car flash this code p0430..... Car has 200000+ km so it's due for replacing thanks
Old Jun 16, 2014 | 02:50 PM
Vlad_Type_S's Avatar
Registered Bike Offender
Bank 2 is the front bank. It might not be the sensor(s): it could be a bad catalytic converter or even an exhaust leak. Test the sensors first. If the sensors are good, replace the cat.
Old Jun 16, 2014 | 02:57 PM
Joey tl's Avatar
04' tl 6 spd
I'm have rv6 HFC ..... Never had a cell come up for about 3 years with the HFC
Old Jun 16, 2014 | 04:25 PM
That doesn't really change anything. The good news is that the RV6 converters come with a lifetime warranty from the manufacturer (can't remember who it is). Try resetting the codes first. If it comes back, look for exhaust leaks near the front cat. If there is no exhaust leak, check the bank 2 (front of car) downstream (lower) O2 sensor voltage. I don't have the specs on hand, but basically it's either the sensor or the converter that's bad. So if you test the sensor and it's good, then you know the converter is bad.
Old Jul 19, 2014 | 04:12 PM
Joey tl's Avatar
04' tl 6 spd
so reset my code ......... car hesitates during acceleration from stop , high speed is good but no light until yesterday and code P0430..... didn't change anything just reset my code this is what my diagnostic tool read
FUEL SYS1 CL
FUEL SYS2 CL
CALC LOAD(%) 41.6
ECT (C) 82
STFT B1 (%) 7.0
LTFT B1(%) 2.3
STFT B2 (%) 12.5
LTFT B2 (%) 3.1
MAP(kPa) 42
Eng RPM 1759
Veh Speed (km/h) 81
spark ADv 37.5
IAT (C) 28
TPS (%) 18.8
Rel TPS(%) 9.8
what do u guys think
ladiesman217
Dec 20, 2016 11:20 AM
SiClone
Oct 1, 2015 10:22 PM
Billu99tl
Sep 13, 2015 11:30 AM
UA7_Ando
Jun 3, 2015 03:45 PM
sunny158
Aug 4, 2008 02:41 PM
