p0300-p0306 codes, please help!
Old Nov 2, 2016 | 04:06 PM
ccrew95's Avatar
Got in my 08 Tl TypeS today and the CEL was on with codes p0300-p0306 (random+each cylinder misfires). It is a manual, however I don't believe I've over rev'ed it, so I'm ruling out bent valves. It isn't really rough idling or holding back on acceleration. Any run down or help would be appreciated!
Old Nov 2, 2016 | 04:23 PM
EvilVirus's Avatar
P0300 ACURA Random Cylinder Misfire Detected
Old Nov 2, 2016 | 07:29 PM
Turbonut's Avatar
That code(s) is not really a misfire, it's just that the ecu doesn't see the predetermined advance after
a plug fire and throws a code, so it's something that is affecting all cylinders.
Plenty of possible problems it may be, but start with the EGR valve, vacuum leak.
Old Nov 3, 2016 | 06:39 AM
NetGnome's Avatar
Maybe loose spark plugs.
Old Nov 3, 2016 | 08:28 AM
ccrew95's Avatar
I reset the ecu and the CEL didn't come back after a couple minutes if idle and revving, haven't driven it yet. I'll look into the EGR valve today. Have an idea of where a vacuum leak would be coming from for this? After the throttle body I would assume?
Old Apr 7, 2017 | 10:26 AM
remspot's Avatar
Any update?
Jbaum
2G RDX Problems & Fixes
Feb 20, 2024 07:27 PM
ssgnco
4G TL Problems & Fixes
Oct 17, 2016 07:24 AM
AcuraOwnr956
Aug 25, 2016 09:31 AM
SuperGreg
Jun 10, 2016 08:02 PM
mattyacura
Jan 25, 2016 06:00 PM
