P0171 & P0174 Fools Gold
Old Nov 19, 2019 | 07:59 PM
GhostTL09's Avatar
Recently picked up a 07MRP Type-S w/135k on the clock. 1 owner with good maintenance records. Drove her home from MD (14hrs with a 3hr stop to see my mom) with no issues. On my last leg of trip I got gas from somewhere. I don't remember because I was so exhausted I just needed a break from driving so it wasn't at my usual QT rest stops. Anyways I filled up and within next 3hrs I was home Veterans day 2019 at 12:01am lol. So i go to work next day no problem. 15 minute ride. Come home no biggie. Next morning I'm driving to work....Boom! P0171 & P0174 my stomach dropped. Long story short after reading up on causes I couldn't help but think it was bad gas. I did change the O-rings on the power steering pump because it sounded like shit when I started the car cold. So i ran the tank empty, put in Lucas Injection cleaner and filled up with 93. Drive car for 2 days & Codes and CEL went away. Today Car passed GA emissions and i got my tag and title. I read all about valve adjustments and 02 sensors and just didn't want to deal with that type of negativity in my life.
So anyone out there going through this it may not be as serious as you think. Especially if you have maintained your TL and not beat her into the ground. I believe my issue truly was crappy highway gas in the middlenof nowhere.
Diagnostic Info empty
CEL Gone!
Old Nov 20, 2019 | 02:54 AM
mariusz439's Avatar
You are right. I did some observations and test for a while. It appeared that emmision codes were thrown only in 2 situations:
1. when I fill up with 95octane at station located near supermarket;
2. when i ride in jams and have no chance for more aggressive ride.
Old Nov 20, 2019 | 11:43 AM
kbouchard1092's Avatar
Ran into this problem with my 07 TL-S 6MT. Updated PCM and never had it reappear. This is a known issue and a service bulliten was issued in july 2011, This is specific to the Type S models: see information below:
TSB #
08-043
July 22, 2011
Applies To:
2007-08 TL Type-S - ALL
MIL Comes On With DTC P0171 or P0174
SYMPTOM: The MIL is on with DTC P0171 (rear bank [bank 1] fuel system too lean) or DTC P0174 (front bank [bank 2] fuel system too lean).
PROBABLE CAUSE: The PCM misinterprets inputs as a lean condition.
CORRECTIVE ACTION: Update the PGM-FI software with the HDS.
Old Nov 22, 2019 | 01:07 PM
GhostTL09's Avatar
I'm gonna hit up dealer to see if this has been done on it or not. Probably not but work the update
dedalus5550
2G RDX Problems & Fixes
Aug 14, 2015 07:35 AM
kocyk123
Apr 17, 2015 07:28 AM
JackSampson
Jun 1, 2012 09:14 PM
Beniot
Apr 16, 2008 12:19 PM
Chet03TL-S
Jun 13, 2003 10:59 PM
