P0134 not cleared with O2 Sensor replacement.
Old Dec 27, 2017 | 01:26 PM
Alex Van Den Kolk's Avatar
4th Gear
Replaced all 4 O2 sensors with OEM sensors. P0134 will not clear and I can not pass emmissions test. What's next?
Old Dec 27, 2017 | 01:31 PM
physically clear the code by un-hooking battery for at least a minute. this will clear the code and if the 02 sensors are working correctly, you wont get a CEL again...
Old Dec 27, 2017 | 01:55 PM
4th Gear
I did disconnect the battery to reset and the CEL always returns. The O2 sensor wiring did not look damaged when sensors were replaced. I have read the O2 sensor fix forums.
Old Dec 27, 2017 | 02:01 PM
I have a bluetooth OBDII dongle that connects to an app on my phone that lets me monitor the 02 sensors.
you have to at least figure out if the 02 sensors are actually reading, and if they're not reading/ready you would have to figure out why
Old Dec 27, 2017 | 02:05 PM
4th Gear
I have the same type of OBD II dongle. How do I check to see if O2 sensors are reading?
Old Dec 27, 2017 | 02:07 PM
I believe the free TORQ app allows you to read the signal at the 02 sensor
Old Dec 27, 2017 | 02:18 PM
4th Gear
I use the same app. Looking at the fault log manager screen with P0134 fault code. I do not see where it would allow me to verify the O2 sensor signal.
Old Dec 27, 2017 | 02:22 PM
I havent actually used the torq app.
you are looking to see if the 02 sensors have power, ie; is it producing voltage?
dontTL'em'nothing
Sep 21, 2019 02:04 PM
Jacques226
Aug 15, 2017 06:15 AM
Adoniram
Dec 17, 2016 05:26 PM
hatchnu
Feb 18, 2016 02:18 PM
LazLong
Jun 16, 2015 01:32 PM
